May 18, 2025, 09:12:44 am *
Author Topic: Not getting any sound out of z3  (Read 8058 times)
LydMekk
« on: November 09, 2010, 08:08:18 am »
Selecting some 16/44 CD wav tracks and click on play get this error messages:
First the appcrash and then the did not start one...
No sound comes out. Vista 32, 4gb. Tried reinstalling into a clean new folder, didnt help.
The system worked on your last generation of versions (e.g. this last spring) , but not after upgrading to the latest z3 version some days ago.
LydMekk
« Reply #1 on: November 09, 2010, 08:44:58 am »
9y-8c works fine.
« Reply #2 on: November 09, 2010, 08:48:00 am »
... but 0.9z-2 works fine also ? (that is what you implied earlier I think)
« Reply #3 on: November 09, 2010, 08:51:01 am »
Please change SFS.ini (in your XX folder) to 00 instead of the 11 in there now. Also lower your Split File Size to 60 or so.
Now try again.
If it works (and I think it will if only 0.9z-2 worked for you), you can change SFS.ini back to 11 and higher the SFS slowly.
LydMekk
« Reply #4 on: November 09, 2010, 08:51:51 am »
Did not try z2 only z3.
LydMekk
« Reply #5 on: November 09, 2010, 08:57:45 am »
To clarify went from y4->z3 and now back to y8c (which works).
« Reply #6 on: November 09, 2010, 09:35:46 am »
Ok. Still try what I suggested.
Page created in 10.092 seconds with 19 queries.
