April 26, 2024, 12:07:50 pm *
Author Topic: NOS1 First Impressions  (Read 7731 times)
BrianG
« on: January 05, 2011, 12:20:10 pm »
Hi all,
I have joined the lucky band of early adopters for the NOS1 DAC, does it live up to the hype?
YES it does!  yahoo
OK a little more detail, first, I've been following the XXHighEnd and NOS1 development since Bert kicked Peter off his forum  Wink
I wouldn't call myself an avid hifi nut but after years of searching for the holly grail of sound reproduction I stumbled upon Bert's forum and built the Oris horns with Onken bass units, I then stumbled upon Allen Wright's site, spent a day with him in Zurich and then built his DIY version of the DPA300b amps.  The pre-amp came from Bert as did the TwinDAC+ and I was a very happy chappy.
So I was content with my lot but why go for the NOS1?  Just curiosity I guess and with the almost "try before you buy" option it was reasonably low risk and of course the XXHighEnd software is optimized for the NOS1 so a no brainer to at least have a listen.
Well what does it sound like?  In my system before NOS1 it was if I had been listening through a curtain draped between me and the speakers, or like listening through something thicker than air (dense air maybe  Happy ).
I listen to the NOS1 and the music has no cloths on!   Nice
The first thing I noticed was a headache, don't run the NOS1 without up-sampling with 16/44.1 material  oops
After selecting all the correct starting point options I immediately wanted to play everything I have just to hear them for the first time.  With the NOS1 I do hear everything and there is a certain pleasure in knowing this is "as good as it gets".
Thank You Peter a job well done! Good job !
Brian
« Reply #1 on: January 06, 2011, 09:52:51 am »
Hey Brian,
Long time...  bye
...and welcome to the club!
... I've been following the XXHighEnd and NOS1 development since Bert kicked Peter off his forum  Wink
Yep, for everything there is a place and here it IS the perfect spot for Peter's XXHighend and DAC developments...  innocent
BrianG
« Reply #2 on: January 18, 2011, 12:01:05 pm »
Chaps,
I have had the courage to remove my pre-amp and drive my amps direct from NOS1.  I was nervous but it all works fine, no pops or bangs from NOS1 and not having the preamp gain the XXHighend volume control stays well within the green.
Brian
Page created in 0.127 seconds with 19 queries.
