April 20, 2024, 12:12:42 am *
Author Topic: 176,400 HiRes Problem  (Read 8481 times)
« on: October 25, 2011, 09:01:15 pm »
Mani visited today for a listen and a chat. Just before he arrived I tried a 176,400 Hires file. It played fine for about 1 1/2 minutes then the sound collapsed into a loud static mess. So I tried another 176,400 file - same thing. I mentioned it to Mani and same happened to him but only on 176,400. No problems with other formats as far as we know (but not sure I have files in all formats though). Just thought we ought to let ya know.
All the best
« Reply #1 on: October 25, 2011, 10:23:35 pm »
All the best
I have the same problem! It happens when trying to play SACD PS3 rips converted to WAV 24/176.4 by Foobar plug-in.
In the past I did not have this problem with my Rolling Stones 24/176.4 Flac files purchased from HDTracks.
« Reply #2 on: October 26, 2011, 12:11:09 pm »
I discovered this myself only a few weeks back. So far I have no clue, nor can I see the logic of it. It seems to be driver related, because as far as I can tell it only started to happen with the 768 driver. Of course I must mention (for others) that this will be an NOS1 thing only.
Point is also that this is about 4x 176.4 (IIRC 192 is ok ? not sure anymore ...), which is not possible in any other situation (because of the 705.6 result). But as far as I can tell it happens at the boundaries of trackparts loading (so, the larger the SFS the longer it will stay away). But it REALLY seems a strange thing to me.
At 2x 176.4 it doesn't happen; at 8x 88.2 it also doesn't happen (nor at 16x 44.1 of course).
Ok, now you found out I really should look into it I guess ...
yes
« Reply #3 on: October 26, 2011, 12:30:31 pm »
If you haven't already tried, you should find Weiss Saracon will do a much better job of conversion than the current Foobar plugin.
Extract the individual DSD files first from the rip, then use Saracon for convert to WAV using TPDF dithering option.
« Reply #4 on: October 26, 2011, 01:52:44 pm »
Btw, it wasn't in the first post, but if I had to decide, this only happens with 4x 176.4. So, playit natively (or 2x) and nothing is the matter.
« Reply #5 on: October 26, 2011, 02:20:33 pm »
Yes, this appears to be the case with me also - only 4x 176.4 is a problem here.
BUT... when playing an HRx 24/176.4 file natively through the NOS1, it sounds pretty good... but taking it to 24/705.6 with QAP makes it sound stunning! But only for a minute or so before all hell breaks loose.
« Reply #6 on: October 26, 2011, 02:54:48 pm »
When others want to try it out :
The hell is quite easy to take here. It's just fuzzy digital sound at the level of the music. Nothing like static (*that* would be hell too much !)
« Reply #7 on: October 26, 2011, 11:26:41 pm »
Played my Miles Davis KOB SACD iso rip tonight, converted from DSD to 24/176PCM, and it played fine at x2 upsampling.
