April 30, 2024, 11:17:44 pm *
Author Topic: Win7 on Mac Mini  (Read 11319 times)
cfmsp
« on: February 02, 2012, 05:18:37 am »
Hello Peter, Mani and others I recognize.
I've a question about the setup & configuration for trying XXHE on Apple hardware.  I'm a total windows idiot when it comes to audio, but have much experience tweaking OS X music servers.  I also have limited Linux experience, but I have been listening to Auraliti PK90 for the last few months.
I'm considering purchase of my first ever Windows license to try out a couple of Windows software players. Note: as a lifelong consultant, I've been exposed to Windows on a regular basis since I move off the mainframe in the early 90s.  Happy
I'm assuming I should pick up 64bit version of Win 7 SP1, either Home or Pro.  Does it matter which?  I'll be expecting to control the Windows music "server" from a Macbook Air. Not sure if I can use all the necessary features of Remote Desktop with the Home version.
My available hardware is a Mac Mini 4,1 (aka mid-2010 thru mid-2011).  I'd be using Bootcamp of course, to run Windows (almost?) natively in it's own partition.  I could also run this on the latest model Macbook Air, but prefer the Mini unless there's an advantage to the latter.
Any setup, install, XXHE-specific issues, concerns, I should worry about if I install Win7 on the Mac box?
Note: yes, I'm quite aware that the Mac Mini is a "cesspool of noise"(TM).  This is why I switched to an Auraliti PK90 toaster, several months ago.  In an ideal world, I'd move to a CAPS type setup, or better, running XXHE via a Linux box (a la Mani's recent setup), but I'm getting ahead of myself.
Any help would be greatly appreciated,
clay
PS, FWIW, I have an XP license
« Reply #1 on: February 02, 2012, 08:54:26 am »
Hi there clay !
I see two reasons to not choose W7 Home :
- No RDC (Remote Desktop Control) possibility;
- Awkwardness with allocating Contiguous Memory (which is one of better XXHE's options for SQ). It can work, but with hassle.
I don't think the Air is to be preferred. At least one user can't get it really right as it seems (this is including the NOS1). This actually counts for everything which we may call "underpowered". It just matters.
The noise itself from such setups shouldn't be the biggest problem, and / because this is where XXHE jumps in and does its job. BUT, things may become out of control when it is about e.g. USB connections which can be too noisy. Of course then you must utilize them for your DAC; otherwise the point is moot. Also not to forget : where the one USB port maybe OK, the other may be completely wrong. So, keep this in mind for later, and test it.
I see no further real problems, apart from a 2 core (which you may have) sure not being better than 4 core with hyperthreading (thus 8 core). This really matters for SQ. And, you might have a 2 core version. Still you can try it, but it may leave you with the feeling "couldn't it be better ?".
It is also worth to mention that actually without exception people keep in struggling with anything which is not on par really. Not because I say so, but because I just see it happening. I hope I'm allowed to say it, but today's example is Claudius who is waiting (forever) for someone to show up in his neighbourhood with an on-par machine so his doubts can be taken away. And, since in the end everybody turns out with that on-par machine, it saves some frustration when it's done right away. But :
Please notice that this latter is about the somewhat more extreme situation including the NOS1. This d*mn thing shows really everything, also what's not the best. So, maybe I am talking you into unrealities, but still it would be true that the underpowered machine is not the best in absolute sense.
Maybe Mani can enlighten you somewhat more about his CAPS, and all I know is that this can be okay for SQ, but may be more slow to your likings on the disc I/O department. Here too, in all honesty, this is NOS1 related and the playback of 32/705.6 which of course is something different than 16/44.1 (hey, that's only 32 times more consuming !!).
So we must be careful not to compare too much with apples and oranges.
Anymore questions ? shoot !
PS: When you install W7 SP1, please shut off the auto updates right away (and never perform them manually either). It would be THE way to let change your SQ underway without knowing whatever happened.
« Reply #2 on: February 02, 2012, 09:14:30 am »
Hi Clay, welcome to the Phasure boards! I never thought I'd see the day... pigs will fly... and you'll be wanting a NOS1 soon!
I have no experience with Bootcamp whatsoever - so sorry, can't help you there. But runnning XX on a number of different PCs? Sure.
I agree 100% with Peter. XX just works more effectively on faster PCs. If you can live with a powerful PC (with the necessary SMPS and fans, etc) then this is the way to go. I myself just can't. Call it psychological or whatever (I don't have the means to really measure this stuff, apart from 'mechanical' noise of course) but I don't want any SMPSs in the same circuit as my hifi, or indeed any fan/HDD noise in the PC. So, I've gone down the CAPS route, as you know. Does it work with XX? Yep, absolutely. And with an XX feature called 'Minimise OS', it really works better than an Atom has a right to.
BUT... if there were a way to totally electrically isolate the PC from the NOS1, there is no doubt whatsoever that I would just put together a big bad PC and stick it in my basement, running off the house AC circuit. Ideally, I'd then want some sort of optical connection to the NOS1.
Oh and although I'm over the moon with my Linux-based Network Audio Adapter, my two NOS1s aren't going anywhere - aong with XX, they're still the best way I know how of playing back 16/44.1.
On a final note, I've tried Remote Desktop. It works fine. But it means you can't use the 'Minimise OS' function in XX as this disables all LAN/WLAN. Apparently, this matters for SQ. (I wonder what affect the LAN connection then has on my NAA... Hmmm.)
Mani
Claude
« Reply #3 on: February 02, 2012, 04:56:08 pm »
Hi Clay,
Installing Windows is quite easy and you will be guided by bootcamp. Installing and using xxhighend is not. It is, if you follow Peters Installationguide close.
Claudius
Dec 1, 2011 (0.9z-6-1)
Windows 7 Pro 64bit *SP1* on sd (Macbook Air)/ Engine#4 *Adaptive Mode* / Q1/2/3/4/5 = *30*/0/0/0/0 (Dev.Buffer = *4096*) / ClockRes = *15ms* / Mixed / SFS = 400 / Playerprio = Low / ThreadPrio = Real Time / Scheme = 3 @ UnAttended /All Services Off/ *Minimize OS = On* / *Double Octo* Arc Prediction Upsampling /24/768 Phasure NOS1 async USB DAC, Driver v1.0.2 -> Octave HP500 SE ->ADAM Pencil (active) (all PCs Lessloss Signature, Lessloss Firewall, ICs Lessloss Anchorwave and HMS Sestetto, 3 Lessloss Blackbodies)
cfmsp
« Reply #4 on: February 03, 2012, 02:35:22 am »
Thanks Peter, Mani and Claudius.
As for the "when pigs fly" comment, well, my reticence was despite huge amount of respect for Peter's work, and your  opinions of it (which I trust).  I just hate the idea of having to buy a Windows license for audio, when I've avoided doing so thus far.
So, I'll get the Pro version.  Have no idea why Ultimate version was suggested for CAPS V2 - more services to turn off I guess.
Is 16B a reasonable amount of disk space?
Mani,  I'm very well aligned with your thinking on smaller processing footprint, power supply, etc.
thanks all
clay
« Reply #5 on: February 03, 2012, 07:36:19 am »
Possibly, but it depends on what you mean. swoon
Each disk space which can hold your music files is sufficient of course, but when you have to buy something for it, get a 2TB. Just because it is affordable.
Try to put your music not on the same disk as the OS disk. That is safer, but also better (this is XXHE stuff for later). But when all on the same disk is unavoidable, so be it.
Thank you for your kind words,
cfmsp
« Reply #6 on: February 03, 2012, 01:45:56 pm »
Sorry, Peter, I should have been more specific.  I meant for the OS partition.
I suppose to do this right, I need to re-partition an entire external drive (to use for music files) in FAT32, for best access via either OS - linux and Windows?
I'm now shamefully aware of the extent I've totally ignored any opportunity to learn about best practices for Windows audio.
thanks again,
clay
« Reply #7 on: February 03, 2012, 02:22:01 pm »
Hey hey, I don't know everything either !
If you really want to access the one partition from the three OSes you mention, maybe you are correct. But I don't know (a thing about Linux). Maybe this is another reason to attach another disk so you can do that the way needed, without touching the OS partion ?
Btw, I never really tried to find it, but I wonder whether I will be able to see my OSX partition when in Windows (7) ...
Maybe not.
Page created in 0.337 seconds with 19 queries.
