April 20, 2024, 02:34:29 pm *
Author Topic: USB CABLE AGAIN  (Read 24162 times)
« Reply #15 on: February 10, 2012, 07:07:10 pm »
over time I realized I can get better cables to a much more lower price.
Hello Juan,
may I have some names/brands
best
joachim
« Reply #16 on: February 10, 2012, 07:39:56 pm »
Hello Juan,
best
joachim
Hi Chris,
Power cords: Grover Huffman http://www.groverhuffman.com/home and Foundation Research LS1 and LS2, the latter (F.R.) I´m not sure if they are discontinued but can be found once in a while second hand for around $300
Interconnection cables: Grover Huffman
Speaker cables: Clear Day Cables http://www.cleardaycables.com/ and other ones without name made by a friend.
« Reply #17 on: March 16, 2012, 06:05:26 pm »
The first day with the Entreq “Challenger” USB cable,
The difference of the  sound  to shelf cable was to hear immediately, finer timbre of all instruments (upright bass, horns and violins) and voices, more air between the instruments.
Reference records are:
“The Shelter In Your Arms” by Sammy Davis Jr.
 “Intermission Music” by Beady Belle ( the duet with Jamie Cullum is a highlight )
“Sunflower” by Wynton Marsalis (horns in heaven and thaat beat of the bass)
“Stolen Moment” by Gap Mangione
The Entreq USB cable is another step up the ladder and now I’m waiting for XXH release 0.9z-7
« Reply #18 on: March 16, 2012, 11:32:07 pm »
Finally - someone.
But it took you long !
Thanks for sharing Joachim - Appreciated !
Bigear
« Reply #19 on: March 23, 2012, 03:59:28 pm »
FYI, I gave the guy from Kemp Electroniks a call (he used to import the Entreq stuff. He told me he was going to supply (in a couple of month from now) a USB cable that would sound even better then the ''Challenger'' cable.
http://kempelektroniks.com/
