July 01, 2025, 03:38:23 am *
Author Topic: Problem reading tracks with different sample rates  (Read 11528 times)
« on: April 28, 2012, 02:32:08 pm »
When I put in the Playlist Area two or more albums with different sample rates, e.g. 24bit/96Khz and 16bit/44Khz, the player stops always when the last track of one album is finished and it doesn´t start to play the track of the next album if it has a different sample rate. I have activated Allow Format Change but it doesn´t solve it.
« Reply #1 on: April 28, 2012, 02:52:20 pm »
Hi Juan,
What I recall is that I solved this a couple of months ago, but IIRC I first created the problem outside of the public version (the one you have). Not sure though, and also you are the first one to mention this after so many months.
Or is it only with Attended perhaps ?
Let me know,
« Reply #2 on: April 28, 2012, 02:56:22 pm »
Let me know,
Thanks Peter,
I play it Unattended.
« Reply #3 on: April 28, 2012, 03:03:15 pm »
Haha, now it looks like you are saying "okay, I will play Unattended, and then the problem is solved".
So, do you have the problem with Unattended ?
« Reply #4 on: April 28, 2012, 03:06:57 pm »
I have the same problem. Attended or Unattended...same thing. I was going to upload a log-file myself if needed but apperently I am no the only one facing this problem.
For me it is an HDCD vs. normal CD (same problem having both in FLAC or in WAV or mixed).
You can select 2 tracks of different kind yourself and hopefully you have the same problem (or not if it is solved in the version you play).
« Reply #5 on: April 28, 2012, 03:09:37 pm »
Sorry, always my bad English...at least it makes you laugh Happy
What I wanted to say is that the problem happens when I play it at Unattended which btw is how I play XX always.
« Reply #6 on: April 28, 2012, 03:38:46 pm »
Ok, thanks both !
... Then I most problably hided away from my memory that the problem sneaked in ever back and "hopefully nobody would notice". swoon
But it's solved for 0.9z-7 anyway.
Thanks !
« Reply #7 on: April 28, 2012, 03:56:54 pm »
Ok, thanks, btw for when the new 0.9z-7?
« Reply #8 on: April 28, 2012, 08:19:07 pm »
Fairly soon now. Happy
« Reply #9 on: April 29, 2012, 04:53:27 pm »
Remember you promissed us more prominent cymbals!  thankyou
Page created in 9.521 seconds with 19 queries.
