July 01, 2025, 09:45:56 am *
Author Topic: 0.9z-7 No Playback  (Read 20394 times)
« Reply #15 on: August 21, 2012, 08:37:49 am »
Is this the PC from your signature ?
Yes its the PC from my signature & Garbage Collect worked fine with 0.9z-6.
« Reply #16 on: August 21, 2012, 09:00:19 am »
Ok, so things did change anyway there. I will look into it.
Thanks !
PS: Arvind, don't forget to get through the Activation Procedure once again (since you were not Activated properly earlier). Now, I don't know whether you changed things such by all your trials that you previously obtained Code will work. So it is better to obtain another right away. Of course I will send back the money promptly.
« Reply #17 on: August 21, 2012, 09:59:14 am »
Sorry I forgot to mention that the Activation was done successfully with the previous Activation Code. Coverart has red border & I could min OS too. In a day or two I will try PA also.
« Reply #18 on: August 21, 2012, 10:23:52 am »
Arvind,
If you only follow the "prescription" !
« Reply #19 on: August 21, 2012, 10:52:32 am »
I took the precaution of checking with Ken Stevens (CAT) & he has confirmed that the preamp & amp has DC Blocker. However I will still check the DC voltage with & without PA before connecting the speakers.
