July 08, 2025, 08:42:16 am *
Author Topic: XXHighEnd does not come forward  (Read 14872 times)
sinister
« on: October 10, 2012, 12:03:28 pm »
Initialization problems after installation, it is necessary to run a few times until the program opens, sometimes I had to reinstall it.
W7 Ultimate x64 SP1->XXHighEnd (09-z7-4, #3 Engine, PlayerPrio-Low/ThreadPrio-Realtime, Clock Resolution[0,5ms], DAC is 24/44,1, SFS 12MB, Memory Organization [Straight Contiguous], Q1,2,3,4,5 - 1,0,0,0,0)->Creative Titanum HD (Audio Creation Mode, Enable Bit-Matched)->2x(SE GM70->Horn)+(500W Mono ClassD Module->Horn Sub)+Plasma Speakers. SilverAudioDesign - www.svpremvs.cc
« Reply #1 on: October 10, 2012, 02:01:11 pm »
Anyone else running into this ? I heard of one other two days ago. Never heard it before, and you seem to be the second, sinister.
Seems to happen when XXHighEnd is started the first time after the install (of an upgrade in its new folder). So, taskbar icon is there, but no XXHighend screen.
Is that your sitiation sinister ?
Again, anyone else ?
If so, how did you solve it ?
« Reply #2 on: October 10, 2012, 02:25:20 pm »
Nothing like that but perhaps related ... ? XX does not come back after playing a playlist unattended. The screen remains dark and I have to Alt-X to get all activated again (incl. Windows).
« Reply #3 on: October 10, 2012, 02:39:58 pm »
Thanks Bert. But that is "sort of" by design. Let's say "wrong design" or wrong-ish, because not consistent with similar situations.
Anyway, not related to the problem of this topic at all.
sinister
« Reply #4 on: October 10, 2012, 02:43:26 pm »
Yes, that's right. Tried to reinstall - again the same thing, how to fix it?
PS A normally open, have to run over and over again, then starts immediately.
« Reply #5 on: October 10, 2012, 03:02:03 pm »
Ah, okay... thanks. That means that my XX copy is doing what is should do.  Cool
Sorry, but I had to ask ...
« Reply #6 on: October 10, 2012, 03:06:49 pm »
But are you saying that right now you can't get XXHighEnd to start properly at all - no matter what you try ?
sinister
« Reply #7 on: October 10, 2012, 03:16:48 pm »
Now works, but I had to reinstall and re-run XX, the first time there is no window - "taskbar icon is there, but no XXHighend screen"
« Reply #8 on: October 10, 2012, 03:26:57 pm »
Okay, thank you very much for mentioning this.
Hopefully not too many others run into it because I really can't tell what's happening in this situation. As said, coincidentally someone else had the same day before yesterday, and although it was solved for him too, I actually have no clue how it got solved. Yea, "just install it again", like you said.
Strange ...
sinister
« Reply #9 on: October 10, 2012, 03:40:34 pm »
And you, after installation, the first time successfully start?
« Reply #10 on: October 10, 2012, 03:42:14 pm »
Can you ask that question again, put into other words ? It is not clear what you mean ... Happy
sinister
« Reply #11 on: October 10, 2012, 03:52:57 pm »
When you install the program, it is normal, the first time start? had a problem like mine?
« Reply #12 on: October 10, 2012, 05:03:10 pm »
No. It should start the first time right away.
Page created in 6.905 seconds with 19 queries.
