May 21, 2025, 05:58:52 pm *
Pages: 1 [2] 3 4 5  All
Author Topic: 0.9z-7-4: Unattended mode behaving like AB  (Read 54933 times)
charliemb
« Reply #15 on: March 03, 2013, 10:38:44 pm »
Yes.  Will do.  (though I'll have to install irfanview on that machine and it is not on the network anymore)
And I'll change SFS MAX from 72 to 12 in case I want to play with numbers <12.
Perhaps premature to report, but last night I had no problems with SFS=2 and Mixed Memory (not mixed contiguous).
Thanks  thankyou
July 2019:
charliemb
« Reply #16 on: March 04, 2013, 02:08:18 am »
Screen capture did not work w/ Irfanview, and would have been very difficult w/ multiple pages.
Can anyone recommend a screen capture program that will automatically scroll can capture the entire settings page?
July 2019:
« Reply #17 on: March 04, 2013, 02:34:48 am »
Hi Charlie,
I don't know the software, but looking for "Screen recorder" brought
this link: http://sourceforge.net/projects/camstudio/
Hope this help Happy
charliemb
« Reply #18 on: March 22, 2013, 03:05:04 pm »
Thanks Alain.   I'll try it.
July 2019:
charliemb
« Reply #19 on: March 22, 2013, 03:11:51 pm »
As an update:
Nothing works still.
1. my disks never spin down
2. I've tired SFS=2  and SFS Max also that small
3. None of my collection is WAV if that matters
4. [ C ] Does not help.  I thought so for a while.
5. Killing xxEngine.exe,  not really a help.
I'll try to get screen capture per Alain.
Basically, I've gone back to Attended playback.  And that has fewer problems with SFS=2, although problems still are there (as previously posted in another thread ..with Play button not responding etc.)
July 2019:
charliemb
« Reply #20 on: March 22, 2013, 07:16:31 pm »
Peter,   Okay, here finally is a screenshot of my settings.
What say you Doctor?
July 2019:
« Reply #21 on: March 22, 2013, 08:44:12 pm »
The Doctor has no clue. Usually when that is the case you are advised some stupid (perhaps) killing activity. But I am not like that. I just have no clue.
Leave Vista ?
And hey, did I ever ask you to post log files ? maybe not ! So what about that ? Switch on logging (bottom of settings) and when it starts to (or is) happening, just post them. XX, X3 and X3PB, in your TemporaryData folder under your XX folder. The newest.
Tell me at which track name it happens and maybe I can see something.
What a crazy thing !!
« Reply #22 on: March 22, 2013, 08:53:13 pm »
PS: Use an SFS of 60 for this and start out with using the [ C ] button. Just leave on your Logging all the time and once you notice it happening, try to count the repeats before your press Stop, tell me those repeates (allowed to be off a few) and mention the track name where it happens. That should give me enough guidance.
charliemb
« Reply #23 on: March 23, 2013, 12:47:27 am »
Okay.  I'll see what I can do.
Leave Vista?  Of course.  That's the eventual answer.  But that is a big project (time) and a big expense (money) and I've already blown my budget on very nice speakers this year, only two months ago.  Big project because this machine is too noisy to invest in.   I'll need a new machine.  I'd buy and install Win7 on this machine if I could transfer it later to a new, quiet machine at some point in time.   But my understanding is that this is not supported.  Can anyone tell me otherwise?
July 2019:
« Reply #24 on: March 23, 2013, 07:13:41 am »
You mean that a W7 install on one machine can not be later installed on another ? Of course that can be done (and is allowed).
Btw, my "leave Vista" was merely a joke. It sort of seems appropriate because it could be the only thing different between you and all of the others. But Vista is just supported, although by now not all features work on Vista (I can't help that).
Let me know your findings (log files) ...
charliemb
« Reply #25 on: March 23, 2013, 02:08:55 pm »
Above you wrote that 60 can't work with Vista.  That's why I moved to SFS=2 (<=12).
July 2019:
charliemb
« Reply #26 on: March 23, 2013, 02:14:16 pm »
How is this done?  Do I "unregister" the old machine before moving to the new one?   ..or do I just never connect to the internet with the new?
July 2019:
« Reply #27 on: March 24, 2013, 11:17:27 am »
While I sure forgot about this, it is not related to Vista. It is your too few memory ...
In the mean time (while you can stuff in some more memory of course), set your Memory Mode to Mixed to try what I suggested. Just to try; later you can go back. Otherwise I suggested SFS=60 to be on a very safe side, but 12 will not encourage for too heavy log file registration just the same (I think; but difficult to predict in your case with this strangeness).
« Reply #28 on: March 24, 2013, 11:22:02 am »
The latter sure is a solution. But otherwise I never heard problems from people. But maybe I'm thick and obviously it shouldn't be able to work legitimately ? Point is : what you are doing just *is* legal, as long as the other machine doesn't exist anymore (hence uses the same Key).
charliemb
« Reply #29 on: March 25, 2013, 12:01:57 am »
Hang on.  We may have a breakthrough.   I don't want to speak too soon, but....
My installation of z83 is incomplete ...and it's working now for two nights.  ???   I forgot to "keep processes" for the two executables which watch over my Logitech mini Keyboard this, the palm-sized one.
I'll keep you posted.  And in the meantime, thanks for all of the attention you've put on this.
Keeping fingers crossed heat
July 2019:
Page created in 10.078 seconds with 19 queries.
