April 20, 2024, 01:33:07 pm *
Author Topic: Win10 10586.36, XXHE 2.03a sounds great to me  (Read 7501 times)
hbrew
Steve
« on: December 31, 2015, 05:51:09 am »
I have read that this version (Win10 10586) doesn't sound good. With the settings I have it sounds very good - compared to XXHE 1.186a on Win 8 (with the Win7 shell); but this also sounded very good. Not dimensionless (as with plugged ears) as people have written.
The depth, dynamics, clarity and details I'm getting is great. The USB cable upgrade made a huge difference on highs that without it perhaps I would not hear the difference.
I would like to hear the other versions that people have written about that sound better -- 10074 for example.
I haven't partitioned a drive in years. Can I partition and not delete my current setup?  I had problems installing Win10 ISO. Was it because I forgot to activate the Win7 Pro (which I have a disk for)? In the end I installed Win 8 from disk, upgraded to 8.1 then to Win 10 10586.
Or can I buy a setup with the best WIN 10 version on a SSD (no noise)?
XXHE RAM OS disk as of 2016.01.22 using Win10586
Player1: SuperMicro X11SPM-F, pre-owned Intel 6152 Gold Scalable 22 cores (set to 20), 6x8GB, Corsair GS600 ATX PS, 2.5-inch SANDISK Plus SSD for RAMOS - remains after booting, M.2 Kinston NV2 1TB NVME PCIe 4.0 Gen 4x4 3500MB/s music disk (or use external via Ethernet); cannot use M.2 NVMe SSD as boot device with CSM legacy boot so used a 2.5 inch SSD for booting; using onboard USB3.0 to DAC with good results but haven't tried my Silverstone USB card. Use KVM with 15 inch "portable" display once booted.  AMAZING SENSE OF REALISM
Player2 (retired): ASRock Fatal1ty X99M Killer/3.1, was i7-5960X 8 cores changed to a pre-owned E5-2699v3 18 cores (set to 14), 48GB 2400MHz DDR4 RAM, RAMOS Win10586 on 120GB M.2 SSD, music files over LAN, ASUS GT210 Silent Graphics card, Silverstone USB 3.0 card
Music Server:  ASROCK BeeBox direct Ethernet connection to player PC
XXHE 2.11 since about 4/2023 for the CPU core selection feature; arc predict; Min OS;attended or unattended; Device: Denafrips v5.0 or KS Amanero Streaming depending on DAC; KS Mode: Adaptive; Device Buffer: 2048 or 4096;  tweaks - 43/1/-/1/1,  Q1:14, Q3,4,5: 1; SFS 1 to 5; Straight Contiguous; Garbage Collect (sometimes can select); Clear Proxy; Denafrips Venus II DAC is 24bit/192KHz, DIY Dual ES9018 DAC is 32bits 384KHz; Cores 3-5; Player Prio:low; Thread Prio:RealTime; Clock Resolution:15ms; Stop Services (desktop, remaining, WASAPI and WIN10); Use Remote Desktop; Don't Keep LAN, PAN or WiFi; OSD Text; Show as Wall Paper
Equipment: Denafrips Venus II R2R DAC and DIY Dual ES9018 Twisted Pear Audio DAC boards using Amanero USB receiver (384KHz) with isolated buffer (ISO7640FM), preamp is DIY Lynn Olson Raven with an added Phono Preamp; Douglas Self Trimodal selectable Class A or Class AB 20W amp; Klipschorns (modified slightly); balanced mains power transformers: one for amp and one for low level equip; Alt. Speaker: ScanSpeak (2) 10" Revelator, (2) Illuminator 4", (1) Beryllium Dome Tweeter, tuned ports
Room Treatment: 4, 4 x 24 x 48 inch panels
« Reply #1 on: December 31, 2015, 08:48:31 am »
Hi there,
Assumed you did not read about it, or otherwise this seems a commercial activity (while I am not much commercial at all) :
Very soon now Phasure has an SSD ready to ship with at this moment 4 OSes on it (1x W8 and 3x W10 Builds), each in "from disk" version and "from RAM" version (boots from RAM and the SSD can be removed from the system). So this is 8 OSes.
Then there is a 9th on it, which is the most normal and again sounds different because "the most normal from disk".
Lastly, we will provide "upgrades", hence downloadable (aready working !) OSes to add to the SSD.
None of them is activated, so you need to provide the license(s) yourself. XXHighEnd on each of the OSes *is* activated.
Price is 360 euros.
Disk with Multi-RAM-boot available for purchase.
If you want to participate, let me know soon (upcoming week I am going to buy all the SSDs).
hbrew
Steve
« Reply #2 on: December 31, 2015, 09:55:36 pm »
Interested. Where would I get the various licenses for Win10. I have disks (and key codes) for Win 7 Pro and Win 8.0 Pro but upgraded to Win 10. Without Windows licenses these this may be pointless.
Thanks.
« Reply #3 on: January 01, 2016, 07:53:31 am »
Don't use that upgraded W10 any more in the same PC where you are going to use this SSD. Now use the (W7 etc.) key for that.
Or buy a license. One is enough.
Maybe investigate how one upgrades to W10 - what's legal and what is not.
It has been spelled out in this forum quite some times as well, but don't ask me where because it was dealt with too many times. Maybe Search brings you to some ?
Anyway, assumed that you use W10 now legally in your Audio PC, you will be legal with this SSD just the same, in the same PC. Ok ?
