February 23, 2018, 11:44:08 am *
Author Topic: Boot Questions RAM Disk  (Read 3654 times)
« Reply #15 on: January 21, 2016, 07:05:45 pm »
Yes, I just came back because I thought I found out (that).
Just logging in to Windows, right ?
For the Stealth LPS PC :
W10-14393.0 - November 13, 2017 (2.09)
XXHighEnd Mach II Stealth LPS PC -> Xeon E5 2640v4 with Hyperthreading On (20 cores) @~720MHz, 32GB, Windows 10 Pro 64 bit build 14393.0 from RAM, music on LAN / Engine#4 Adaptive Mode / Q1/-/3/4/5 = *30*/-/*1*/*1*/*1*/ Q1Factor = *40* / Dev.Buffer = 4096 / ClockRes = *15ms* / Memory = Straight Contiguous / Include Garbage Collect / SFS = *0.90*  (max 120) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 3-5 / Not Switch Processors during Playback = Off/ Playback Drive none (see OS from RAM) / UnAttended (Just Start) / Always Copy to XX Drive (see OS from RAM) / Stop Desktop, Remaining, WASAPI and W10 services / Use Remote Desktop / Keep LAN - Not Persist / WallPaper On / *OSD Off* / Running Time Off / Minimize OS / XTweaks : Balanced Load = 43 / Nervous Rate = 100 / Cool when Idle = n.a / Provide Stable Power = 0 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = Stable / *Custom Filtering Highest for 705600* / Always Clear Proxy before Playbck = On -> USB3 from MoBo -> Lush USB 1m00 -> Phisolator 24/768 Phasure NOS1a/G3 75B (BNC Out) async USB DAC, Driver v1.0.4b (*8ms*) -> B'ASS Current Amplifier -> Blaxius Interlink -> Orelo MKII Active Open Baffle Horn Speakers.
Listening To Music Becomes Much More Fun With XX!
« Reply #16 on: January 21, 2016, 07:06:18 pm »
Jup
M & M: Music and Motorcycling !
« Reply #17 on: January 21, 2016, 10:51:17 pm »
Gerard,
I am glad that Alain understands, but it beats me what you are talking about;
you changed your response; prior to that I understood and agreed. But now ?
to get to the code area. The XX code....
To get the code area what ?
Sorry ...
It's not that I understood all, but I will wait to see it by myself. Remembering what Gerard said will get all its means when I will access my system tomorrow evening Happy
Desktop with ASUS Sabertooth X79 motherboard,Intel 3930k 6 cores (+ 6) at 1.2 GHZ,16GB ram 1333Mhz,Win 8 pro 64 bit with no updates,OS + XXHE on external Sata III SSD (Esata), music (WAV) on external 5200 rpm drive through network, OS MInimized, XX with engine 4 adaptive,4096 (buffer size), CPU with scheme 3,Player = Low,Thread = RealTime, Q1 = 14,Q345 = 1,1,1,Q1x=1,Clock res = 1ms,Stop Desktop Services,Stop Remaining Services,Stop Wasapi,,LAN on,persist = no,all OSD off,SFS =0.4,PE off,PA off, Arc Prediction,x16 Upsample, Straight Contiguous,Clearlink USB 2 cable,Phasure NOS1 DAC,Meitner PA-6 preamp, Spectral Audio DMA-180  Power Amp, Tannoy System 15 DMT II, Tannoy St-100 supertweeters, Tannoy TS2.12 subwoofers (2).
Diede
« Reply #18 on: January 22, 2016, 02:59:54 am »
So anyone, please, what do you see at first boot ?
For me everything worked as mentioned in your notes, so the 10565 trial version first.
I installed all necessary drivers etc in both 10565 and 10586.0, booted in MinOs later RAMOS, everything went smoothly for both :-)
Great work!
No impressions yet, to late to have a listen.
Next step: music on LAN.
Diede
PS: I was just in time to pull out the internet connection, once I disabled Windows updates I downloaded some drivers ect ...
« Reply #19 on: January 22, 2016, 03:09:08 am »
Thank you for this feedback, Diede !
Gerard, what I was thinking about last night ... Can it be so that you touched some buttons when you first booted ? I mean, the time out for booting is set to 2 seconds, and if within that time the keyboard is touched, the boot process will be "stuck" (intendedly) in the Windows (!) Boot Menu and then it depends what you choose ...
I know, it could be far sought, but especially because it worked as intended for Diede as he just explained, I can't understand how it can be different for you.
Notice though that very theoretically it can because after each "clone" of the disk I had/have to apply some adjustments (using that Boot Menu of XXHighEnd) and without real notice I can have denoted 10586.0 in your case as the first-next Boot.
Btw, there are two green stickers on your disk; there can be a marking on them (think a left-hand and a right-hand sticker, when you hold the disk so that you see them on the top);
Any marking visible ?
