July 01, 2025, 11:57:22 am *
Author Topic: Shut down issue for RAM OS 10586  (Read 5008 times)
« on: January 25, 2016, 02:42:10 pm »
Playing from RAM when I shut down the PC last night I first remounted the RAM OS drive using the "Cancel" button in the Boot Menu screen. I then closed the boot menu screen and then closed XXHighend. Then using the 10586 start button I hit Shut Down. All looked well, it started to shut down and I saw a message saying settings were being saved to permanent storage; however I ended up at the log in screen instead of shutting down. After having this happen 3 times in a row, I booted into 10586 base and then had no problem shutting down.
« Reply #1 on: January 25, 2016, 04:11:22 pm »
Hi Brian,
First off, look here :
How to shut down PC when in RAM OS.
Then :
I don't think what you tell there is completely correct; So :
When you do that, nothing is saved anywhere, plus your mentioned
won't be occurring, as this only springs from XXHighEnd's Shutdown feature.
Lastly :
You can initialize the shut down like that, but it is not necessary, as the system will mount the Disk after you inserted it, automatically. Again, see Arvind's post (my response to that).
Ok, one more thing :
I surely believe you but don't ask me how that happens. Possibly if I do exactly the same as you did, that will happen over here too. But for example, if you imply *and* a shut down via XXHighEnd *and* one in parallel via Windows itself, I'd say strange things may happen. And it looks like you applied such parallel processes, although I don't see you writing that literally.
heat
Does this help you ??
Page created in 1.918 seconds with 19 queries.
