April 26, 2024, 01:20:51 am *
Author Topic: The SQ of XXHighEnd Unregistered  (Read 9360 times)
« on: February 12, 2008, 09:35:04 am »
On another topic.... you recently found that XX sounds better once it is Registered.
Do you have a work around for this yet?
Brent, indeed another topic. So I created one for you ...  Wink
I never thought about it until your question ... but running XX UnAttened would take distance from that unintentional phenomenon (and I think UnAttended was brought later than when we found out about the difference in SQ). UnAttended is just possible in demo mode.
My humble suggestion is that you make XX free and charge extra for features that have no affect on sound quality.
Personally I don't think it can work like that. XXHighEnd was created for the sound quality, and any additional features would be kind of stupid to pay for, because *those* are just rather normal features you see all over the place. Also, because those features (mainly the Library Functions) can be near equal, worse or just super bad related to the other players, I won't get myself into "complaints" about that, while actually it was not, is not, and never will be about that. It's just a necessary thing. So a twist as proposed will suggest wrongly IMO.
People might think that "features" like MP3 support is something that doesn't belong in a high end player, and that *that* actually is an example of what people might want to pay for as an additional feature. Well, once you fell in love with XXHighEnd for SQ in the first place I don't think MP3 playback will get any better for SQ in any other player. The SQ of MP3 with a bitrate of 256 and higher is already better than what I perceive from any "normal" USD 100,000+ system playing full quality CDs from a CDP.
Actually with 0.9u this is so outrageously much better again, that maybe a time will come that many with their so called cr*ppy MP3 pile of music will end up with XX. Those who don't care or like the 3D pictures stay with iTunes.
Of course I don't need to respond so extensively to your question and well meant suggestion Brent, but with the above I want to make clear that my heart is in the sound quality and that stupids like me even work big time on the best SQ of MP3. Do I do this to satisfy some teenagers (who are well over 30 now Grin) ? no. I do this because MP3 isn't inheritently worse. It's the stuff around it (like playback) that s*cks. Try it.
And on another note : CD singles just died, and are brought to you for free now in MP3 format.
Concluded, it is sound quality what I hunt for (including "2 times better each other few months" yes) and it is that what one pays for.
brentw
View Profile WWW
« Reply #1 on: February 12, 2008, 09:59:01 am »
Sorry but I don't know all the terms/lingo you use in regard to your XX program yet. That leave me and probably a few others confused as to the Sound Quality of the unregistered version.
Let me rephrase the question.  What are your plans for futures versions? Is the SQ of the Demo mode going to be the same as when Registered? And if so in what version?
If this is technical challenge then maybe you can make a Registraion Key that only works for 1 minute at a time or something like that. That way we can all be Registered when doing a demo.
I am hot to try it and see for myself, but not ready to pay money. Which is probaby the same as 90% of the people who want to try it.
Windows7 64bit / XX.9z-6-1 Engine4 *Special* Buffer=32 Q0 / USB / DIY TDA1543 NOS 16bit DAC
« Reply #2 on: February 12, 2008, 10:22:57 am »
Hello Brent,
A part i can answer also.... Peter meant that when you play Unattended the SQ is the same like the one we  have... When you open up XX and look at the bottom/right (Playlist area)  you see Unattended... Just check that and you will have the "best" way to test it. And the SQ is the same way we have and it is the best SQ XX has...
This could be helpfull too..
http://www.phasure.com/index.php?topic=279.0
Grtz
brentw
View Profile WWW
« Reply #3 on: February 12, 2008, 10:29:25 am »
Thanks for the clarity Gerard.
Now I just have to wait for version 0.9u to surface so I can try it in Windows2008 Server Happy
« Reply #4 on: February 12, 2008, 11:47:04 am »
Apart from that your "SQ problem" is out of the way by now, this just wouldn't change anything. Of course you are not long enough around here to just "know" that everything in software matters, but indeed it would be so that your suggested solution would influence sound for the worse. Not that I "stated" from the beginning this would be so ... the contrary; all is too way out to believe. But if you'd look back in the forum posts ... each time I said that I didn't change anything explicitly for SQ, people fell all over me with the message this was so anyway. Now *knowing* it, it is just true. Whether you -at this moment- can hear it is another thing, but you can sure learn to hear it.
Computers ...  Happy
Page created in 0.116 seconds with 19 queries.
