May 11, 2025, 12:05:48 pm *
Author Topic: XXHighEnd Model 0.7h  (Read 9138 times)
« on: June 02, 2007, 06:41:52 pm »
Changed :
  • If everything is allright, all about the trackselections is stable now. Therefore I ask you to please report any further anomalies. Concentrate on no sound at a next track (only when the player suddeenly quits it’s normal because of the demo version), more than one visually selected track while you didn’t ask for it (you can you know), skipping a track, prematurely ending a track (one or two seconds currently would be normal Happy), or anything else you probably are good at. Cool
    There *are* issues left with sliding the playposition pointer, so there's no need to report that.
    Note : Just before publishing this version I had to change something on the above, and since testing all the combinations takes many hours, I can only hope I didn't destroy something ...
  • Clicking an empty Playlist area caused an error which is now solved.
  • Added some lacking ToolTips.
  • Disabled the Pause button when appropriate.
  • Changed the content of a few error messages.
  • Loading a saved Playlist onto an empty Playlist area would give an error, and didn’t show the coverart for the first track. This is now solved.
Note that this version is prone to sound different. If you have any comments on that, please put them on the board !
Edit : If you're downloading this version for the track selection stability ... never mind. There are still issues.
* XXHighEnd-07h.zip (54.07 KB - downloaded 643 times.)
« Last Edit: June 03, 2007, 10:47:04 am by PeterSt » Logged
Page created in 9.581 seconds with 19 queries.
