April 26, 2024, 07:11:53 am *
Author Topic: Tidal: A problem occurred with registering this track  (Read 5336 times)
« on: September 29, 2017, 07:21:45 am »
This is the dialogue box that pops up for every track when I am preparing a stream for a Tidal album.  I hit continue each time and it seems to work but obviously something is wrong.  The files copy ok to the non-temporary folder and play just fine.
« Reply #1 on: September 29, 2017, 07:51:11 am »
Hi Anthony,
Can you test the 2.08b below for me ?
(paste over your 2.08(a) install)
If it works you can keep on using it.
* XXHighEnd-208b-X.zip (1742.14 KB - downloaded 364 times.)
« Reply #2 on: September 29, 2017, 08:30:52 am »
Thanks Peter, that seems to work.
dsm
« Reply #3 on: September 29, 2017, 02:07:37 pm »
I also had this problem and the new patch seems to fix it so far.
Best,
David
Page created in 0.139 seconds with 19 queries.
