September 27, 2023, 11:47:30 am *
Author Topic: Tidal - Unable to connect to the remote server  (Read 11412 times)
coliny
« on: October 05, 2017, 06:12:02 pm »
JUst trying to get into tidal
First time Tidal login info was accepted by XXHE.
 but when I search from within XXHE I get message "Unable to connect to the remote server".
Checked with Tidal app and I can login ok with it.
Changed Tidal password but XXHE did not ask for the new password. Gone back to original password for now.
Colin
« Reply #1 on: October 05, 2017, 07:21:29 pm »
Hi Colin,
In your XX folder there's a TidalSesssion.dat file. If you delete that, the popup for the credentials will show again.
Otherwise if you (want to) send me your Tidal email addres and password (by email !), I can try from here. I know of one other situation and in that case it works over here. And if I send you mentioned .dat file created here, it will work on your side too.
I have no idea what can be wrong in such a situation.
coliny
« Reply #2 on: October 06, 2017, 08:53:38 am »
That error occurs when Artist is left blank.
Tried search for Artist - Madness (other fields blank)
No results were returned (no messages either)
Colin
« Reply #3 on: October 06, 2017, 10:34:55 am »
Hi Colin,
This is difficult for troubleshooting because our result sets will be different (for Holland different from the UK). Anyway :
When I leave blank the Artist I just get a result (for all I look for but for safety I just tried Paranoid) and when I look for Artist Madness I receive a screen full.
What Album (in the "general" field) do you search for ?
« Reply #4 on: October 06, 2017, 10:36:49 am »
Btw, a nice pitfall will be that you have MQA Only ticked, and the Artist does not have any MQA. With Madness this is the case ... (at least over here).
« Reply #5 on: October 06, 2017, 11:16:37 am »
... For the life of my I can't imply that error message, so I really like to have all the data to copy this issue ...
coliny
« Reply #6 on: October 06, 2017, 03:43:37 pm »
If I search Artist = madness , Album = blank , I get no results.
If I search Artist = madness , Album = complete madness , I get no results.
If I search Artist = blank , Album = complete madness , I get "unable to connect........"
In the Tidal App I can search for "madness" and get all their albums.
Colin
« Reply #7 on: October 06, 2017, 04:55:02 pm »
Colin, you mean the one you see below, right ?
Do you have the same {...} number in your Tidal player ?
See the Share link.
Many results here.
I get the album.
I again get the album.
What happens when you paste this in the Album/General field ?
https://tidal.com/album/70742844
(that too works here)
coliny
« Reply #8 on: October 06, 2017, 05:45:21 pm »
Yes I have same link when I search in tidal player.
But no result when I put link in Album field
Colin
coliny
« Reply #9 on: October 06, 2017, 06:33:34 pm »
Updated 2.08 to 2.08d and search is returning results now.
Regards
Colin
« Reply #10 on: October 06, 2017, 07:02:57 pm »
Ah, OK Colin.
coliny
« Reply #11 on: October 07, 2017, 09:22:48 am »
But next step does not work. When I try to Prepare Streams I get message:-
GetTracksForAlbum Error :.......
click OK to that and get message:-
Something went wrong with obtaining Meta Data For:...........
Regards Colin
« Reply #12 on: October 07, 2017, 10:14:50 am »
So basically the same problem.
You could try to switch on logging, let the message about the Connection appear, let that be and grab the newest XX- log file and post it.
I'm afraid though that the relevant logging is just not active in the production version.
I feel that you have some general odd problem in your HTTP traffic (for the part XXHighEnd uses) or it is the problem I mentioned first, after all. I never tried it, but I could try to use your TidalSession.dat file to see the problem is in there (you now don't need to send email + password but only the .dat file, by email).
Did you (ever back) use the activation procedure on this Windows 10 machine ? I ask, because that would imply the same HTTP kind of traffic (protocol).
Another idea could be that you use MinOS on this PC and this is not really the idea of it. I mean, this was never tested and requires services could be off. So are you ?
Is the UAC On or Off ? (see rightclick on Stop). It should be On.
coliny
« Reply #13 on: October 07, 2017, 10:38:28 am »
email sent
