July 02, 2025, 12:30:36 pm *
Author Topic: Music stops playing  (Read 21596 times)
« Reply #15 on: February 24, 2018, 11:05:56 am »
At present I don’t have the graphic card in the Audio PC & neither a monitor, keyboard & mouse connected. Let me set up all these & try to boot into 10586.0 Base.
« Reply #16 on: February 24, 2018, 12:17:24 pm »
10586.0 Base works fine. However Just For your information the XXHE version which came up was 2.06a.
Would you want me to boot into 14393.0 Base & try it out?
« Reply #17 on: February 24, 2018, 12:27:51 pm »
Ah yes, that test was actually first. Please do.
The XXHighEnd version should not be related.
« Reply #18 on: February 24, 2018, 12:43:55 pm »
14393.0 Base has the problem as in 14393.0 Ram; XXHE screen does not open.
« Reply #19 on: February 24, 2018, 01:12:28 pm »
heat ... so you are lucky and nothing is really the matter. However, your 14393.0 got corrupted. This means copy back the "- Copy" version.
Test that briefly at first and then don't forget to expand it. First look at the size of the current (corrupted) 14393.0 so you can make it the same.
Still questions ? just ask ...
« Reply #20 on: February 24, 2018, 02:05:55 pm »
I looked into drive D: & it doesn’t have a “- copy” version of 14393.0. It only has MyW10-14393.vhd
However I had copied the above OS version & saved it another hdd. Don’t know if that is useful!!
« Reply #21 on: February 24, 2018, 02:39:18 pm »
Maybe you deleted it so save space. It was originally there (it is for everybody).
Of course it is !
« Reply #22 on: February 24, 2018, 02:48:37 pm »
I’m pretty certain I haven’t deleted it.
As I understand I should delete the corrupted version & copy paste the one I have in the other hdd. Right?
Having done that I should boot into 14393.0 Base, test out all is working ok & then boot into RAM OS?
« Reply #23 on: February 24, 2018, 03:06:50 pm »
Yes. But take care that the name becomes "original" again (remove the "- Copy").
Yes. And also check whether you have XXHighEnd 2.09 in there. If not, your copy is from earlier on and you'd need to upgrade it with the UpgradePatch file (paste over, etc.).
« Reply #24 on: February 25, 2018, 09:40:19 am »
All good here, back with 14393.0 RAM OS, XXHE version 2.09.
The only issue which has cropped up is after loading a playlist & hitting play, a window pops up:
“Free Memory
Attempts: 11 Current CPU% level of process 4.89341. Continue?”
If I click on continue the music starts & plays normal.
Wonder what this pop up means & how to get rid of it?
« Reply #25 on: February 25, 2018, 10:16:54 am »
Hello Arvind,
OK, Good !
In Settings (Memory section) there's something like "Garbage collect". Flip the state of that and the message won't appear.
If you did that previously as well, it is plainly that and solved. If you're sure you never touched it, try to imagine what has changed since the previous 14393.0 "install". Notice the size I referred to yeaterday.
And btw, if this happens once a day this is not a problem at all. Or, if it happens one time just after a boot, also no problem. But otherwise it shouldn't be there "continuously" or otherwise I will tell you to get an "on par" PC. But as you know, you already have that ...
So maybe something was changed.
« Reply #26 on: February 25, 2018, 11:49:30 am »
I think I found the problem. The memory organisation was set to mixed instead of straight contiguous.
Thanks for your help & support.
« Reply #27 on: February 25, 2018, 12:31:45 pm »
Yes Arvind, that will matter !
Not that I ever heard of it, but surely enough many people brought forward this issue as you did today, but you are the only one of which I could tell that it couldn't be the PC.
If I only remember it for the next time ...
Thanks and enjoy again !
