April 16, 2024, 11:48:33 pm *
Author Topic: Vista64bit support  (Read 17263 times)
« Reply #15 on: June 02, 2008, 10:25:01 am »
Thank you Brent.
That debug prompt was indeed left in there because I expected it to happen. Small problem : I don't know anymore why. However, apparently you now have it. Here's the (only) comment I put to that :
*** 18-02-2008,PS, Below goes wrong in Windows2008 (?) ***
This is about setting the Wallpaper;
Maybe you can dig up why I put this comment there ? It *must* have come from you somehow ...
Note that this comment is not 64 bit related; only Windows2008.
Do you remember the debug version I posted in order to let you test Windows2008 ?
The below zip is similar, but for 64. Please let me know which messages pass by.
PS: It can well be that setting an official Wallpaper (I mean, put there by you) helps. Or the other way around, remove it explicitly ?
... Oh ... What I just notice in the program, is that the "preparation" for changing the Wallpaper (which the error is about) is performed unconditionally. Meaning : the setting "CoverArt as Wallpaper" won't change a thing to this.
Edit : I don't klnow whether you got some results from this, but please note that below zip is not compatible with (due) higher XXHighEnd versions. So it can be used with 0.9v-1 only.
* XXHighEnd-09v-1a.zip (199.17 KB - downloaded 334 times.)
« Last Edit: June 21, 2008, 01:28:19 pm by PeterSt » Logged
