July 02, 2025, 05:04:20 am *
Author Topic: Wishlist (again) in future versions - when time permits  (Read 10627 times)
LydMekk
« on: March 10, 2008, 04:07:56 am »
As there's more and more talk of room-correction, active speakers etc. etc. on the web these days, could it be interesting implementing a digital EQ in XX for correcting the frequency curve in the player? Not with any measurement input, but just a digital EQ with On/Off possibility in addition to 8-12 bands?
Any hope?  Happy
The dreaded fubar/foobar (!) has this as I remember...  evil
« Reply #1 on: March 10, 2008, 09:34:09 am »
Oh, I think you can be sure it will be in there, some time. Permit me to have a couple of PEQs instead of normal EQs. Say, an infinite number per channel, until the CPU is choked.
Of course I just learned myself that cpu useage with 176400 is still virtually zero, what I maybe not expected. This tells me that indeed all the overhead is in the drivers, and I can kind of do what I want. It would be "sport" anyway, since my fun around computers has always been, say, tuning.
Btw, once the PEQs are there, it's no big deal to present them as high-pass and/or low-pass, hence crossovers. The remainder is assigning the lot to the appropriate channels.
I must say that I'm kind of surprised that some people already have 8 channel amps running, which only is encouraging to get this going.
When time permits.
Ava12
Headphone Audiophile
« Reply #2 on: May 27, 2008, 07:11:31 pm »
Since this is a already a wishlist let me please make this advice:
maybe (almost certainly) it's a gimmick, but could it be possible to show the XX symbol as Wallpaper, if there is no Coverart in one folder?
« Reply #3 on: May 27, 2008, 10:18:39 pm »
That shouldn't be that difficult. Happy
« Reply #4 on: May 31, 2008, 09:02:16 am »
Just to remind you to make a folder functionality for easier playlist management. Eventually you make the structure and then the user can add subfolders himself when organizing his number of playlists.
« Reply #5 on: May 31, 2008, 09:29:06 am »
Uhhm ... scratching Remind me of Playlists with sub folders ? You must be confused with something else.
Or you drank a too expensive cognac maybe ?.friends
« Reply #6 on: June 01, 2008, 05:24:42 pm »
Pedal,
Since you didn't respond anymore, I guess I need some ...
My response may have looked like some joke, but I really don't know what you mean. Of course, I can imagine something with a(n appointable, like I agreed upon earlier) folder for playlists and then sub folders in there, but the latter would be something which was never discussed before afaik (so that one about "reminding" Happy).
The setup needed for that would be way different from the current one, and personally I don't think it is worth it (??). Why ?
Because I don't see the difference with setting up similar by means of Galeries (see Library Area). And you can have as many sub folders as you like in there.
Note : Selected tracks in the Playlist Area + Rightclick allows saving to a Galery with the tracks in the Playlist Area as a base).
One thing : The latter (I think) currently saves the name/path a kind of wrongish (although it will work at playback), but *that* can be solved.
« Reply #7 on: June 01, 2008, 05:54:06 pm »
... which I just did (for the next version).
Page created in 5.622 seconds with 19 queries.
