April 26, 2024, 08:40:32 pm *
Author Topic: Library sort order  (Read 20877 times)
« Reply #15 on: September 22, 2008, 10:01:16 am »
-  make the appendage of (WAV), (FLAC), (MP3) in the library listing a 'tickable' option in the settings panel.
I'm afraid this is too much woven in the code while at the same time it has its purpose for that code ("is this a FLAC album ? then do such and so"). I think this will stay ...
Not a problem Peter. If It's not easy to do without having to re-invent the wheel I understand.
- keep a history ( perhaps the last 10 entries ) , of the paths shown in the entry just to the right of the Date Picker button.
Now I see this working here (yes) it is actually quite convenient. You'll see ... Happy
Thanks for the idea !
bewdy .. this one I had been thinking about for a while to ask for.
Thanks again Peter for your willingness to listen to all our ideas and suggestions.
« Reply #16 on: October 06, 2008, 03:51:24 am »
Thank you for the addition of the "Favourites" library paths in 0.9v-7 Peter ... much appreciated.
The amendments to the "date picker" code in 0.9v-7 have also allowed me to identify new albums in a way I wanted .. great job there. Just one small quirk with the "data picker" though ... if I want to select ONE specific day, say the 20th September, I can't have the 'from' date and 'to' date set the same. There currently needs to be at least one day difference between the two date ranges. In the example above, if both dates are set to 20th Sep, then no results are forthcoming. If I try again from 20th Sep TO 21st Sep, then I get the results for the 20th as I wanted. ( It might also pick up results for the 21st also, but as I don't have any for that date I have no way of telling at the moment). If it is possible to amend your code so that both dates on the picker could be the same, it might help someone in the future from falling into the same trap as I did, and not being able to get the results expected.
Thanks again   thankyou
« Reply #17 on: October 06, 2008, 10:42:06 pm »
Hi Russ,
I tried September 24 u/i September 24 ... no luck.
25 u/i 25 ... no luck.
24 u/i 25, but 24 and 25 appear.
Aint that smart ? swoon
Thanks for pointing this out. One could go crazy of it.
