![](http://www.phasure.com/Themes/SandBox/images/post/xx.gif) |
« on: October 30, 2009, 03:36:16 am » |
I've had W7 sitting on my shelve for since Monday now .... but I'm too scared to change 'perfection'. Ah ignorance is bliss. But the devil inside me says ... 'but, but... try it...'
PS I think AUDIODIDAKT is the devil speaking inside my head... out, demon out.
0.9z-8-3a WAV/CUE files on HDDs via MB FW400>; Win7 pro ttp://www.phasure.com/index.php?topic=352.msg4021#msg4021); [XXHighEnd player Qs 7, 0, 0, 0, 0; eng 4; adaptive; scheme#3; player priority low; thread priority realtime; clock res 5ms: SFS 420 ![Wink](http://www.phasure.com/Smileys/default/wink.gif) dac is 24/192 w/32bits; Play Unattended; Stop Services ticked; Wallpaper & Show Back ticked - Mirror Image unticked; Start Engine unticked;garbage collect ticked; copy files to XX-drive; *quad arc prediction upsampling*: straight contiguous:>PCI FW800 card>Fireface 800 DAC [latency 2048 samples for 176.4]; usb/ethernet/mb audio shut off @ MB
« Reply #1 on: October 30, 2009, 05:57:40 am » |
LOL ![very happy](http://www.phasure.com/Smileys/default/very_happy.gif) Its a lot of work, I know, but we have to move forward, haha Don't know for sure if it sounds better, but I think it does, so if you are in for challenge............. Some back ground: I have had so much trouble with Vista (NOT XX RELATED), I fully trust W7 as the better OS. Especially with SSD, really it is better and sure faster. (Peter will be joining us soon) Roy\\\ Sunshine, moonlight, goodtimes, boogie
earflappin
« Reply #2 on: October 30, 2009, 10:47:45 pm » |
I never tried Vista, rather stuck with XP Pro. Compared to XP Pro Windows 7 is a BIG improvement. It is smoother, much faster and more stable. In terms of sound quality, it is noticeably better than WinXP Pro (I've been using Samplitude as a player before getting XXHighEnd).
But....I'm having issues with 0.9y4 on my Windows 7 music server - you can see my other thread detailing the issues. Peter is working with me, but right now I can only use engine 2 and even then I am getting errors and it takes multiple attempts to get a file to play.
« Reply #3 on: October 30, 2009, 10:58:16 pm » |
Welcome earflappin,
Cool nickname btw (this what you experienced first time hearing xx, I guess) haha
Peter will sort it out together with you, I know for sure.(all problems will be sorted out)
Then you will experience Engine3, that is the real deal.
Grtz Roy
earflappin
« Reply #4 on: October 30, 2009, 11:04:18 pm » |
Thks Roy! Yep, I am very confident that Peter will work through these issues. I have been very impressed with his responsiveness and communication skills....I think his technical skills speak for themselves!
I can't wait to hear engine 3. BTW, does Arc Prediction only work on engine 3?
BTW, are you running 0.9y4 on Windows 7? If so, what has been your experience? I'd feel better knowing if other Windows 7 users are experiencing the same issues.... otherwise, there might be a config or machine specific issue on my server.
Best, David
« Reply #5 on: October 30, 2009, 11:35:49 pm » |
All works flawless here, (I am on latest version, with W7 RC build 7100, yes) Very happy with how it sounds. Different set-ups can cause different problems. (don't worry) My friend is here to listen to some music, for a couple of hours. So have to go............ ![whistle](http://www.phasure.com/Smileys/default/whistle.gif)
earflappin
« Reply #6 on: October 31, 2009, 05:50:56 pm » |
Just wanted to note that I now having 0.9y4 running flawlessly on my Win 7 Pro 64bit Zalman music server with a Lynx AES16 card with 64 bit driver. And it is the best digital I've heard. Using the unattended setting makes a very noticeable improvement. And I prefer using the Arc Prediction on CDRB...to my ears it greatly improves sound quality....one has the very real sense that detail has been added back on these 16/44.1 recordings.
I want to thank Peter and Roy who were of great help in helping me not only get it running, but understanding the optimal set-up parameters. I'm going to read everything on this site to accelerate my learning curve.
BTW, I want to be clear that the issues I was having had nothing to do with XXHighEnd or Win 7, but were rather in selecting the correct AES16 PCI card channel in the XXHighEnd Settings.
Anyway, I would definitely recommend the move to Win7.... This is Microsoft's best operating system IMO.
« Reply #7 on: October 31, 2009, 07:48:06 pm » |
David, thanks for the feedback.
I hope I didn't overdo the promises about the Alpha and everything. From now on it will only get better at learning your best settings. Maybe it stops somewhere before I find something new, but I'll keep on trying to be ahead of you.
Regards, Peter
earflappin
« Reply #8 on: October 31, 2009, 09:26:19 pm » |
Thank you Peter. I am so happy I came across XXHighEnd. The future of computer audio is so full of potential and its clear to me you are pushing the envelope very hard. That's great. 16/44.1 with your Arc Prediction algorithm is a definite breakthrough in the SOTA IMHO. Well, I hope you can run quickly because I've already implemented HotKey, tweaked my Windows 7 using your Vista Dead guidance and my own experience with tweaking Windows, and have an e-mail into Berkeley to find out how to turn off OS on my Alpha DAC. BTW, is there the potential for a "zero" jitter interface between the computer and DAC? The Berkeley guys regard their AES/EBU interface as superior to Toslink and coax - my ears agree. They told me that they opted not to include support for Firewire or USB out of concerns the necessary circuitry required in the DAC would be too noisy and degrade SQ. However, they do have a HDMI connector for a future interface. I've read about your NOS DAC and thoughts on interfaces. I'll be staying tuned to those developments. ![Wink](http://www.phasure.com/Smileys/default/wink.gif)
« Reply #9 on: November 11, 2009, 02:47:01 am » |
And SeVeReD how is progress on W7 install ?
« Reply #10 on: November 11, 2009, 10:56:09 am » |
And SeVeReD how is progress on W7 install ? Hi guys, I'm still alive and checking the boards here even though I've been quiet. I haven't setup W7 yet. Will do when I get more time ... which is being taken up by a new flame. I must say, part of why I think she's falling for me is my stereo, hehe... now thats a twist I like. ahh and she likes it loud. XXHE for the win or she'd be running for the volume knob.
« Reply #11 on: November 11, 2009, 11:00:06 am » |
ahh and she likes it loud Here in Holland we say "hard". ![swoon](http://www.phasure.com/Smileys/default/swoon.gif) ![Happy](http://www.phasure.com/Smileys/default/rolleyes.gif) ![swoon](http://www.phasure.com/Smileys/default/swoon.gif) Anyway, your new flame is noticable allright. Great !!
« Reply #12 on: November 11, 2009, 11:07:44 am » |
My flame does to ![Wink](http://www.phasure.com/Smileys/default/wink.gif) Only i turn it to the right and she to the left... Hmmmm ![rofl](http://www.phasure.com/Smileys/default/rofl.gif)
« Reply #13 on: November 11, 2009, 11:52:39 am » |
ahh and she likes it loud Here in Holland we say "hard". ![swoon](http://www.phasure.com/Smileys/default/swoon.gif) ![Happy](http://www.phasure.com/Smileys/default/rolleyes.gif) ![swoon](http://www.phasure.com/Smileys/default/swoon.gif) Anyway, your new flame is noticable allright. Great !! alright alright, that too.
« Reply #14 on: November 12, 2009, 11:49:05 pm » |
Anyway, I would definitely recommend the move to Win7.... Today I did make a start to install Win7 64 bits version. I had some troubles to start the installation process on the SSD because I did not burn the Win7 ISO file on the lowest DVD write speed! Yes there more people having the same problem. "Trying to install Windows 7 and get hung up after clicking the "Install" button on boot-up using DVD. It loads for a bit, then tells me a CD/DVD Driver is required and can't be found" After some time I start with the last installation of the soundcard drivers "Audiotrak HD2" .......f...k!....Strange but true I can't manage to install the drivers. I don't know why. Simply nothing happens after a double click on the .EXE. I did a test on a XP machine (without the soundcard) same result. The installation proces didn't start.....suggestions? At the moment I'm back to Vista (another harddisk) listening to XX!
