July 01, 2025, 07:56:15 pm *
Author Topic: Missing button in GUI  (Read 9757 times)
4est
« on: October 13, 2012, 06:15:05 pm »
I have XX installed, activated and running, but I am missing the buttons to the right of the volume slider. The multiplier button, arc predict, phase ect. The whole chunk above the library. Any suggestions would be helpful.
« Reply #1 on: October 14, 2012, 11:36:06 am »
Hi 4est,
There's a "splitter bar" denoted [1] at the top of it. Slide that to the right far enough ... (you will see a rectangle popping up when far enough).
4est
« Reply #2 on: October 14, 2012, 04:23:43 pm »
Silly me!
Thank you Peter, I feel stupid and yet I had moved it- just not far enough...
« Reply #3 on: October 14, 2012, 04:25:53 pm »
haha
PS: I should have called you welcome here.
... welcome here ... Happy
« Reply #4 on: October 14, 2012, 08:34:32 pm »
I'm missing in the left pane, top right, the one level back button in the library. How do i get it back.
Johan
« Reply #5 on: October 14, 2012, 08:53:28 pm »
Ha ! Good question Johan. I never payed attention to that.
(you will mean the Treeview in the left pane)
But I guess you are right ...
Will look into it.
Regards and thanks,
4est
« Reply #6 on: October 16, 2012, 02:59:41 am »
I am honored Peter! Thanks again.
