July 01, 2025, 10:09:46 am *
Author Topic: Want a good laugh ?  (Read 30667 times)
« Reply #15 on: November 26, 2007, 11:12:15 pm »
Hi
Well here i am again from my laptop..... Well i think i am a bit done with my music pc.... Spooler error came also up....  unhappy
Peter i will answer the core thing later....
Little bit  Cry now...  Grin
« Reply #16 on: November 26, 2007, 11:14:24 pm »
I recognize this. Dunno at this moment. But the "1 minute" can be prevented.
Too late ?? Happy
Can i??
« Reply #17 on: November 26, 2007, 11:34:13 pm »
For now everything works again!!!  Happy
« Reply #18 on: November 26, 2007, 11:36:57 pm »
I recall ... Sasser Worm.
The "1 minute" thing is an official Windows feature, of which I am sure I have seen that it can be shut off (to cover for problems). Please Google yourself for it (searching for the Sasser Worm should let you bump into it somewhere).
And scan your system ...
I'm sory in advance if I'm not right on this. But then you'll be glad anyway. Happy
« Reply #19 on: November 26, 2007, 11:45:30 pm »
Thanx
Also for the double click!!  Happy
« Reply #20 on: November 27, 2007, 08:29:47 am »
I recall now ...
There's a process lsass.exe; when you delete that, you'll get the "1 minute" thing. Now, it's my guess that this process might not get enough cpu cycles to let know it is running (when the OS asks for it, or whatever), and then it would be the same as killing it (and get the 1 minute message). Or ... or it just terminated itself like the other processes (the spooler service being the first).
So if it is not the sasser worm, then it might just be the same as the stuff this topic (thread) is about. Actually I'd put my chances on that.
Now, careful with those priorities guys, maybe I don't want to be responsible for your crashing systems ... Rules
« Reply #21 on: November 27, 2007, 10:23:03 am »
I can't find any Sasser worm..... I am sorry for my bad English but are you actually saying that i can try to delete Isass.exe?
Ofcourse your not resposible.....  smirk Grin
« Reply #22 on: November 27, 2007, 10:41:38 am »
No, I am noty saying that, although you can try it for fun (it can't harm and your PC will reboot).
Btw, it is Lsass, not Isass.
And in my last post I implied that you - most probably - just will NOT have this worm. Please read again ...  Happy
« Reply #23 on: December 03, 2007, 03:18:41 pm »
I have Vista fresh on my pc right now. But the spooler error apears every 10 min..... Before the reinstall in did not have that...
Is it possible that i shut that error off?
For the rest all looks better/good!  Happy
Grtz
« Reply #24 on: December 03, 2007, 04:01:33 pm »
General good advice: install windows offline (network cable unplugged)
Then install a good antivirus (nod32 or kaspersky 7)
Then plug the cable and do all updates (antivirus first)
I have installed vista x32 and x64 on my computers several times and never had this spool error. I have had other errors and in general doing all windows updates and NOT installing cr*ppy codecs fix everything.
« Reply #25 on: December 03, 2007, 05:08:18 pm »
I can't imagine how that Spooler service can shut down several times. Maybe you talk about some other message as I think ? Or maybe it starts itself again ? (maybe it can, I don't know).
Also, did you try it with all priorities to normal ?
« Reply #26 on: December 03, 2007, 06:49:24 pm »
It was the spooler error for 4 time's in a row... But at this moment nothing yet..  Happy
Set it to normal...
Grtz..........
