July 01, 2025, 09:02:39 am *
Pages: [1] 2 3  All
Author Topic: UEFI & GPT Boot Problem  (Read 43105 times)
« on: April 07, 2014, 11:42:14 am »
This is not super important but I just wondered if anyone has any experience of this.
My PC is the same spec. as the XXHighEnd PC. So it is UEFI and all "BIOS" changes I make are in the UEFI menu. I recently bought a 4T Seagate disc which I have set to GPT.
All fine so far and with the OS on another disc (using a smaller MBR disc) I can see the 4T Seagate (all of the 4 T in one or more partitions).
The problem arises when I attempt to install W8 on the 4T disc - it will not install on the GPT disc. If I set it to MBR then W8 will install but then I do not see all of the 4T on the disc.
It seems that the PC cannot be booting into EFI and so I  removed all bootable devices apart from the internal DVD rewriter and in "BIOS" I noted that the DVD writer was listed with two boot option one was UEFI. So I then selected the UEFI and inhibited the other selection. So then the PC could only boot from one option ie the UEFI DVD rewriter. But it will not boot returning an error message that there is a problem with the boot device.
I just wondered if anyone had trodden this path before?
P
« Reply #1 on: April 07, 2014, 01:17:31 pm »
Hey Paul, in the paperwork that comes with your 4tb HD, there should be a link to a Seagate utility that you need to download to format the drive for UEFI. Once you've run the utility you can load W8 and it will see all 4 tb's.I've done that now on two 3tb drives. Let me know if you can't find it cause I saved that utility somewhere.....I think.
« Reply #2 on: April 07, 2014, 01:22:55 pm »
(I read Brian's post in the mean time, but I don't see the relation with how I experienced the problem)
Me. Happy
Paul, I think you tried all what I tried myself, and I couldn't work it out other than making it MBR. And I even tried with hex editors and what not.
In my case it wasn't about > 2TB (which would require GPT to see all above the 2TB (4TB in your case)) so I could give up easily.
If you ask me this is just a W8 problem, because whatever is thrown at you I never experienced with W7. Similar is the necessity to remove all other drives in order to make the one you want bootable.
While the latter problem is fairly often described hence known, the thing about the MBR necessity is not. Or at least it wasn't back at the time when I tried to deal with it (6 months ago ?).
So ... not much helpful, unless I prove that it just can't be done and it is thus a fact. But maybe I did not try all. For example, that this is related to UEFI BIOS (which you seem to imply ?) I did not know.
Lastly and maybe somewhat helpful, to get a better grip on it all I used a second PC to create the partition, format it and all necessary to let W8 install more easily, but that did not help either. Anyway that works more fast.
So, sorry
« Reply #3 on: April 07, 2014, 01:24:32 pm »
Hi Paul,
It happened to me too, but at the time I was too impatient to check for a solution.
This link may help you ? http://support.microsoft.com/kb/2581408
It says that you need to format the drive in GPT partition type prior to installation, so I guess that you need to have the OS working on another drive to do so.
But this is not all: you also need to use UEFI instead of BIOS, but at this point I suppose it means that you specify "UEFI" boot type (or something like that) in the BIOS for that drive...
Since I finally set for having just an OS on a SSD and the 4TB drive through network I did not need to do this, but thought it could help...
PS: I think that Brian has the solution Happy There is certainly a utility on the Seagate website for this situation...
« Reply #4 on: April 07, 2014, 01:29:32 pm »
I think this is what Brian mentionned for Seagate ?
http://knowledge.seagate.com/articles/en_US/FAQ/218619en
« Reply #5 on: April 07, 2014, 01:32:24 pm »
Yes, there's a link to a "DiscWizard" utility at the end of the article. It works for W8 though it only discusses W7.
« Reply #6 on: April 07, 2014, 02:25:35 pm »
Thanks Guys  -  As far as I can tell the disc utility allows to set the disc to GPT (I can do that anyway no problem) and if the disc is MBR then it can "trick" the OS into seeing all 4T. Those are not really my problems.
I am sure (as far as I can be) that the PC is booting with UEFI on top of BIOS (and I guess that is the case for most people) - so many of the UEFI features are available but it is not a "proper" fully fledged UEFI boot. For that reason only MBR discs can be used to load the OS.
It seems that for years Apple have been using UEFI and even at this late stage Microsoft still have not been able to get it sorted out properly.
« Reply #7 on: April 07, 2014, 03:31:25 pm »
Not sure I understand your issue Paul. After using the utility and formatting in GTP I was able to load the os (both W7 & 8)on a 3 tb drive which recognized all 3 tb's with no partition. Hope that makes sense.
« Reply #8 on: April 07, 2014, 03:33:40 pm »
scratching
haha
« Reply #9 on: April 07, 2014, 03:45:24 pm »
Writing too fast. Happy I have two 3tb drives: one running W7 and the other running W8. Each was formatted with the Seagate DiscWizard utility and then I was able to load the OS's, which are able to see/use all 3 tb's respectively.
« Reply #10 on: April 07, 2014, 04:48:25 pm »
Looks as though sorted now - the problem was getting the PC to boot in EFI which it now is. I also had to install in one large partition and had to configure partitions after the OS was installed. So far so good.
« Reply #11 on: April 09, 2014, 07:47:08 am »
Since getting EFI working properly on my PC there is one advantage that I was not expecting.
Playing music over my dynamically stop / start LAN there are now no delays at all in fact with 1Gb LAN speed I can't tell any difference between playing music over LAN and from a local HDD. Even after a reboot the LAN is immediately available.
There may have been a problem before I was not aware of (although to be fair the delays were not too bad) but it could be because the LAN is now "handled" by EFI rather than by W8 - whatever it is a welcome improvement!!!
« Reply #12 on: April 19, 2014, 10:47:35 am »
Hey ...
Maybe in the future this is going to help someone - but not sure whether it is really related :
I have been working with 3TB disks sufficiently enough to know that they work with one (3TB) partition as long as they are GPT formatted. Notice that I am not talking about booting here. However, I now have a 4TB Seagate, formatted that GPT as one partition, and that goes wrong when something like 13GB is copied to it. So it looks like this really requires that special Seagate formatting (DiscWizward) ?
Also, I read that Seagate applies some "special formatting" themselves when the disc leaves the factory (so to speak). So that smells somewhat.
I've now made two 2TB partitions on it, and so far so good (60GB copied on to the first partition).
« Reply #13 on: April 19, 2014, 10:59:00 am »
Scratch that; it again failed (now at 80GB). So or the disk just fails or it needs that DiscWizard which I am going to try now ...
« Reply #14 on: April 19, 2014, 03:24:17 pm »
Next attempt :
I now used the DiscWizard;
Originally I had it created a GPT partition, well, if it did anything at all. So since I could not check that, before making another copy attempt I changed that to MBR. So one 2TB partion and one for the remainder came from that. Next I tried to use the "extended paration" function, but that gave me an error. And so I left the two partitions be.
Now 650GB has been copied to it without problems.
But I can't say I like this much ...
Disk is a ST4000DM000.
Pages: [1] 2 3  All
