July 02, 2025, 04:51:58 pm *
Author Topic: Drivers MB ASROCK  (Read 6270 times)
« on: June 07, 2015, 07:09:17 pm »
The cd with drivers does not work anymore with W10. Did you get them from the Internet?
« Reply #1 on: June 07, 2015, 07:31:19 pm »
Gerard, very good remark.
Actually I wouldn't know. What is the (error) message you receive ?
All I know is that I used the W8.1 drivers. So at some stage they came about (I recall a version 3.x + but not even sure a this moment) I and simply used those.
All went fine with those although I recall something like a very long time before the first (the one with the .inf's) started - thought it did nothing and next started it a second time.
Otherwise I can't imagine that anything for W10 is about because just nothing is.
« Reply #2 on: June 07, 2015, 07:33:55 pm »
The install cd just wont start installing the drivers. I Look on the internet for them.  Happy
