July 02, 2025, 01:09:55 pm *
Pages: 1 [2] 3 4 5 6  All
Author Topic: NOS1a (v1.0.4b) : Fifo errors  (Read 60830 times)
« Reply #15 on: January 23, 2016, 10:41:33 am »
No really,
The 5 track there were some USB and Fifo errors during playback. Really random. But only a few and only one time 2/3 of the track.
« Reply #16 on: January 23, 2016, 10:43:40 am »
If we think back (years), we recognize ticks and such at track boundaries. Well, Unattended assumed (so that is the prerequisite !) :
The sound engine doesn't know about track boundaries; all is concatenated as one super large file (or stream if you want). Still a tick ? then something can not cope with the knowledge that for the sound engine it is one large stream all right, but for the PC it is not as it needs to do more things.
All we can say is that if you'd observe the errors, you can trust your ears when you heard a tick or glitch at a track boundary.
But set the SFS higher and undoubtely you will see a different behavior because you wil stress the PC less.
Also let's keep in mind my own observation about (or thinkering about) a very low SFS : we lose samples. This works so since the before last 1.xx version and the Q3,4,5 at 1 thing (at first it was Q5 only as I recall). So that also allows for the crazy low SFS while things keep on playing - and now instead we may observe lost samples.
But the errors will be all over the place ...
So I say it once again :
At least for 10074 I am 100% positive about the errors because I always heard them, but, it stabilizes (say it requires a minute max).
And in addition to this the crazy thing : no, I never looked at the errors because whatfore; I know they are there (because I hear them).
« Reply #17 on: January 23, 2016, 10:56:31 am »
Btw :
I already see one "mistake" I make when talking my own observed errors at testing the cables :
We do this with Hires material (24/96) which really matters a lot for stressing the PC. Think 3 times more (compared with 16/44.1).
And it is already known that with Hires the SFS can not be that low ...
Anyway, where I told that I need to set the SFS to 1.00 because otherwise I see errors anyway, this is always with 24/96. I don't even know about 16/44.1 ...
N.b.: I use the 96 because of implying the highest sampling rate over the USB interface (768000).
Arjan
« Reply #18 on: January 23, 2016, 11:28:07 am »
Updated silverstone driver and firmware, but errors are still there and I always hear them. I now use a normal, but isolated silverstone.
Both in ram or not I get these errors and ticks. Also with sfs on 4. But I now use 0.10 again.
I use 10586, unattended and attended.
Switched the usb cables, short on the dac, but that seems even a bit worse.
Changed the short usb on dac side for cheap usb cable, so long Clairixa on pc, still errors and ticks.
Next cheap usb from pc to Intona, no more errors and ticks!
Final test to be done, use of mobo USB ports, but I have to make them active first....
I think Intona is also part of the issue.....combination pc - Clairixa - Intona.
Regards, Arjan
March, 2024 (2.11)
« Reply #19 on: January 23, 2016, 11:43:04 am »
Arjan, thank you for all this work !
So we need to focus on Clairixa on the PC-Intona side. Hmm ...
I am going to test a few things now.
« Reply #20 on: January 23, 2016, 11:44:36 am »
Btw :
Would that be ours ? (shipped with the NOS1a)
« Reply #21 on: January 23, 2016, 12:05:16 pm »
My PC currently runs at 500MHz.
10586.0 from RAM.
16/44100 upsampled to 32/705600
I can play up to SFS=0.05 without errors (but can be one time a few, fairly quickly after pressing Play).
With SFS=0.04 it goes wrong and Kernel Streaming errors are continuous.
Meanwhile someone is making a 30cm for me ...
« Reply #22 on: January 23, 2016, 12:08:31 pm »
Btw, you guys have "Copy To XX-Drive by standard" activated, right ?
Without that it is errors all over the place because of the Network being too slow to pump the SFS trunks fast enough.
The OSes were shipped with that active, but if you deactivated it ...
Arjan
« Reply #23 on: January 23, 2016, 12:09:09 pm »
Yes Peter, the usb cable shipped with the NOS1.
regards, Arjan
March, 2024 (2.11)
Arjan
« Reply #24 on: January 23, 2016, 12:13:31 pm »
Yes, immediate ticks, no sound at all with deactivated Copy To XX... Just dddddddddddddd. If you say this you know.
But the errors are on Kernel streaming/WASAPI and not on USB stream and Fifo...
So different behavior.
regards, Arjan
March, 2024 (2.11)
« Reply #25 on: January 23, 2016, 12:18:49 pm »
Correct.
If you have a hint on what could be special (different) between you and me, don't hesitate.
I don't mean our glasses. Happy
So I am trying to let it go wrong, but not, so far.
Is that 10074 at your side ?
I will try that now.
Arjan
« Reply #26 on: January 23, 2016, 12:20:11 pm »
My PC currently runs at 430MHz.
10586.0 from RAM.
I can play up to SFS=0.05 without errors.
This is in unattended!
Similar behavior.
regards, Arjan
March, 2024 (2.11)
« Reply #27 on: January 23, 2016, 12:24:57 pm »
I can't do a thing actually (I missed the delivery yesterday arrrrggg), but has someone tried to increase slow down the ClockRes or bring back the processor speed at its nominal value (3.2GHZ) ?
Just a thought...
« Reply #28 on: January 23, 2016, 12:35:15 pm »
10074 is not easy for me at this moment because at creating the RAM-OS disks I destroyed something in there (in my own !) and I don't even recall what. swoon
But doesn't matter since you use 10586.0 just the same, Arjan.
Anyway, maybe I learned something ...
I went back to 10586.0 but now the BASE boot; I just thought it could be more convenient. Now :
Especially in 10586.0 this is utterly more slow (but PC at 500MHz only of course) but actually so slow that it was the reason to change my PC from 430MHz to 500MHz.
So starting up XXHighEnd takes maybe 4 times longer than when booted from RAM (strange in itself).
And now I really can't provoke any error ... (ok, not in 5 minutes of time).
Not finished yet and possibly premature, but maybe there is a relation.
« Reply #29 on: January 23, 2016, 12:43:35 pm »
No, this is unreliable;
Now I have the Kernel Streaming errors randomly, which is logic (for me) because the SFS of 0.12 is too low for the reading of the file which is on disk now. You could say : Oh, this can work with that low SFS but now it requires a normal RAMDisk first.
So never mind.
What we can learn from this is that Kernel Streaming errors are "source" ((slow)provision) errors. So a too slow PC so to speak.
