July 01, 2025, 09:47:21 pm *
Pages: 1 [2] 3  All
Author Topic: OS and XXData File Issues  (Read 30281 times)
« Reply #15 on: July 09, 2017, 03:55:45 pm »
Hey hey hey ! Congratulations !
Just announce yourself and I will probably be there instantly.
Good that you did not do anything without reason.
« Reply #16 on: July 09, 2017, 04:20:21 pm »
Thanks and very much appreciate the help! Had no idea how wonderful it is to hold in your arms the baby of your "baby"!
« Reply #17 on: July 10, 2017, 01:49:48 pm »
Please check email, am standing by now. All is set to go.
« Reply #18 on: July 10, 2017, 03:09:50 pm »
I just did and ... too late. Of course I only now realize that you wanted to do this prior to your daily work.
I'll have a better focus tomorrow. Happy
« Reply #19 on: July 10, 2017, 07:40:01 pm »
OK Brian, I could look into it via Teamviewer after all.
Ehhh
This could be the weirdest thing I ever encountered in my IT life. All what's in all those files in that folder, turned into spaces. So I think you said they were not empty - and I don't know how you observed that, but for size you are correct. For contents - spaces in everything.
Now if you know that a space as such is nothing special in computerland (it is just an ascii value of 032 IIRC), then it looks like something deliberately blanked it. But it is ONLY about files with text in them. So FYI not only your PLXX files but also the LBRY files (and IIRC another file type). But e.g. not .XXSS because there's not huban readable text in there. Eh ... "because" ??? Well, yes, that is what it looks like.
The source is already on the native drive (D: when you booted into one of the BASE OSes, like at this moment in 10586.0). On a side note if helpful at all - I checked all OSes and only 14393.0 contains a few playlists, but maybe better a few (it's a dozen or so) than losing them all. Because I think that will be the case : you lost all those files.
What I would do and which could very far away help :
Boot into the TRIAL OS (set date to Sept. 2 2015 first) and when in there go to a Command Prompt (cmd) and type :
chkdsk c:/f:
It will ask you to reboot and before the boot completes the c: drive will be checked agains errors. When this finishes (may take a while like 30 minutes) you can boot into 10586.0 again and see whethere the files now contain data. Just rightclick-open or edit from Explorer to see it. Data is there again ? then you're good. Not ? then it is lost unless you made a backup somehow. And, a backup of the .vhd file would do it. So if you meant in the earlier post to restore such a backup (file), then yes. If you meant to restore from the original copy I provided, then it won't help (that wil lnot contain any of your data).
Let me know whether the chkdsk helped.
Lastly, I left the system with 14393.0 attached and you will see on-screen the XXData contents in an OK fashion for all there is. You may copy that XXData folder as a whole to a USB stick, and restore it later after the intended trials and if they don't help.
If you want to leave this screen (or reboot) click e.g. the c: drive first, so this (x:) will close.
« Reply #20 on: July 11, 2017, 02:04:22 pm »
After getting the OS log-in password screen, as described in my first post, and hitting the reset button, the pc booted normally. I then started XX,selected a playlist and received the message that the playlist was empty. Tried others with same result. Opened explorer, clicked on C drive and then opened the DATA folder. In the data folder I clicked on the playlist I tried to play, it opened in notepad as usual, AND THE TRACKS WERE THERE! I then went to the library, selected an album and all played fine. I rebooted the pc, got the same result and I then made the first post in this thread.
WTF! How could this be that it may have been deliberately blanked? That computer has never been connected to the internet. Most of the time when it boots the Server pc is not on, so the audio pc is not even connected to the network until I establish the RDC connection. Do I need to check for a virus on my audio pc?
Will do but probably won't get to it untill the weekend.
On a side note if helpful at all - I checked all OSes and only 14393.0 contains a few playlists, but maybe better a few (it's a dozen or so) than losing them all. Because I think that will be the case : you lost all those files.... Lastly, I left the system with 14393.0 attached and you will see on-screen the XXData contents in an OK fashion for all there is. You may copy that XXData folder as a whole to a USB stick, and restore it later after the intended trials and if they don't help.
Thank you, thank you, thank you. Such a bummer though, to lose that many playlists.....
Brian
« Reply #21 on: July 11, 2017, 04:03:56 pm »
To add to the mystery I remembered the following on my commute this morning:
As soon as I opened the DATA folder on the C Drive of the audio pc, clicked on the playlist and determined that the tracks were in fact still "there," I immediately copied/pasted it to the Desktop of the music server pc. I believe I said this in my first post here. HOWEVER, when I checked yesterday all track data was gone from both the DATA folder on the C drive of the audio PC, as you found yesterday, AND from the DATA folder I put on the desktop of the music server pc. How could this not be some kind of virus?
« Reply #22 on: July 11, 2017, 05:45:20 pm »
Brian,
The phenomenon "virus" slipped through my mind several times, as nobody is really going to blank the contents of such files. But viruses also noy really, I'd say. Anyway when I mentioned "deliberately blanked" I referred to no normal computer process would do such a thing at any time - and then referring to the "blank" nog being a computer thing at all. So maybe nulls or any other random character (like _ or whatever) but a space is too coincidental.
The strange thing is too that all the file types involved are uncommon file type (I made them all up myself). So why exactly these ?? It is also not that the files of concern are subject to some regular XXHighEnd process. They are just never touched unless you (as the user) address them.
The only thing "plausibe" I see is that something did something with a specific code page. I mean, text as such would be obtained in there under a certain "code" which causes it to be readable for you. For example, would it be chinese in there, the code(page) would be a different one because the characters are different.
But what would do such a thing. W10 failure ?
Edit : I did not tell it so explicitly, but I could see that all the "positions" as such where still in there. It is only that the normal characeters turned into spaces. You can just text search (via Notepad) for the spaces. If you Select All you will see the lines in there.
« Reply #23 on: July 11, 2017, 05:51:47 pm »
I wonder what happens when you copy such a file to another PC and look at the contents from there.
I feel that it can be some kind of authorization issue, related to that password question you received.
« Reply #24 on: July 11, 2017, 06:13:25 pm »
Peter, will let you know what happens when I check the disc for errors with the procedure you provided above. Would certainly be great if the tracks reappear as you suggest they might. Again, thanks for your time on this!
Brian
« Reply #25 on: July 11, 2017, 09:03:16 pm »
chkdsk c:/f:
To reset the date to Sept. 2 2015, I need to do that in the BIOS, yes?
« Reply #26 on: July 12, 2017, 07:59:40 am »
Not necessarily. But it would be more clear to yourself what you are doing, and it will be less dependent on the OS herself which will change it again. So I better admit the Yes.
« Reply #27 on: August 13, 2017, 06:13:25 pm »
Hi Peter. I finally got around to trying the procedure you described below but I keep getting an Invalid parameter - /f:
chkdsk c:/f:
Not sure why /f: is invalid parameter.
Am trying this hoping to get my playlist data back. Thanks in advance.
Brian
« Reply #28 on: August 13, 2017, 08:40:34 pm »
Brian - oops ... it is /f (not /f:)
I hope this helps !
« Reply #29 on: August 13, 2017, 09:01:08 pm »
Thanks, will give it a try this evening. Hope you and the family are having a fabulous vacation.
Brian
Pages: 1 [2] 3  All
