June 13, 2025, 09:06:59 pm *
Author Topic: 2.08d on WS2016 first impressions  (Read 23079 times)
bodiebill
« on: October 01, 2017, 08:33:24 pm »
First impressions of 2.08d:
  • Gorgeous sound.
  • When starting the pc I get an error: "explorer.exe – System Warning – Unknown Hard Error".
  • When I start playing XXHE the Remote Desktop connection to the PC is lost. This happens in unattended mode as well as attended mode. I then have to hard-reboot my pc to get into the OS again. I also tried without stopping LAN and/or checking persist in the settings, but the connection is lost in any case.
Any ideas? As you know, I am on WS2016. Not sure whether it is related to that. I did not have this issue with 2.07 on WS2016.
Cheers, Dennis
Windows 10 Enterprise LTSB 1607 build 14393.0 (tentative settings, still experimenting)
HDPlex 100W Linear PSU / Streacom FC5 / HDPLEX 250W Hi-Fi DC-ATX PS converter / Supermicro X11SAE -> Intel i3-6100T with Hyperthreading Off (2 cores), C-States Off, ECC RAM 16GB / music on LAN / XXHighEnd on A: (3GB RAMDisk) / Engine#4 Adaptive Mode / Q1=14, Q3=1, Q4=1, Q5=1 / Q1Factor = 1 / Dev.Buffer = 2048 / ClockRes = 15ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = 0,1 (max 60) / not Invert / Phase Alignment Off / PlayerPrio = Low / ThreadPrio = Realtime / Scheme = No Appointment / Not Switch Processors during Playback = Off/ Playback Drive B: (3GB RAMDisk) / UnAttended (Just Start) / Stop Desktop-, Remaining-, WASAPI-Services / Keep LAN - Not Persist / Don't do anything with WallPaper / Minimize OS / XTweaks : Balanced Load = 43 / Nervous Rate = 1 / Cool when Idle = n.a. / Provide Stable Power = 0 / Utilize Cores always = 1 / Time Performance Index = *Optimal* / Time Stability = *Stable* / Custom Filter *Low* 705600 / Upsampling ? / -> USB3 *from MoBo* -> Lampizator USB cable -> nas4free music server or local MS-EX SLC usb drive / HDPlex Linear PSU / Streacom FC5 PC i3-6100T 16GB RAM / Windows 10 Enterprise LTSB / XXHighEnd  with minimized OS / APlayer with foo_dsd_asio (optional: Audiophile Optimizer 2.20b5 / Fidelizer Pro ) or WTFplay (Linux) / SOtM tX-USBhubEX / Audiophilleo 1 + Pure Power + Audio Aéro Prestige Signature or Uptone Regen + Lampizator Lite 7 DSD256 / Lightspeed Attenuator / Cayin A-88T / Spendor SP100 + 2x REL T5 / Taket H2 + TR2; Hifiman HE-6
« Reply #1 on: October 01, 2017, 09:07:41 pm »
Dennis,
With always the anticipation on a fresh OS install ...
Is this in Minimized OS as well ?
I ask, because Windows 10 has a famous kind of bug of not being able to sustain the RDC connection in Normal OS while it is fine in Minimized OS.
The Explorer error is also know, but actually from Minimzed OS and shutting down / rebooting (and an ealier W10 Build than today's).
That happening in Attended mode would be new to me (or maybe I just never tried - if only this happens in Normal OS and not in Minimized OS).
bodiebill
« Reply #2 on: October 01, 2017, 10:02:33 pm »
Actually it is the other way around: in normal OS, RD stays connected, in attended as well as unattended mode.
When I went back to minimized mode: this time it went well in Attended; but in Unattended the connection is always lost and I have to hard-reboot the pc.
Also, a few times the pc froze at "Waiting for the Group Policy Client".
The explorer error did not return; I hope it will stay away.
* postscript *
Interesting. I de-activated 'Keep LAN Services' and then, playing from a local usb stick, the RD connection stayed intact during Unattended playback with Minimized OS. Actually, that is the way I usually play (pre-converted) wav files, so I could live with that.
« Reply #3 on: October 02, 2017, 09:16:22 am »
I think I know what is going on in there - some specific check for a combination of the OS Name (which is W10 for the desktop version and WS2016 for the server version), which check(s) must be performed for WS2016 as well. For 2.07 this would have worked out OK because there the server version was just denoted W10 ...
So let me try to find all the code checking for this ...
« Reply #4 on: October 02, 2017, 10:09:24 am »
In Settings, Services and OSD section, there's a Stop W10 Services button. Do you have that active (red) ? If Yes, can you quickly check what happens with your RDC connection if you deactivate that ? Please apply the deactivation in Normal OS and then boot into MinOS.
If you are not there at this moment to try it, just let me know that, so I will not be waiting for your answer (and continue with something else first).
« Reply #5 on: October 02, 2017, 10:40:42 am »
For this one, see below 2.08e (paste over 2.08d would be best for my own interpretation of matters).
This is only a test and the question to you whether you are still "able" to see this "waiting for" message. If not and you are persistent in being sure it has gone, there will be a next step in this one.
I also eliminated a check for 14393.xxx (14400.xxx actually) so for anyone who has a newer build than that (not you Dennis, unless very recently) a certain approach is now done for those newer builds just the same (resulting in something which was necessary from of 14388).
* XXHighEnd-208e-X.rar (1428.04 KB - downloaded 501 times.)
bodiebill
« Reply #6 on: October 02, 2017, 12:57:50 pm »
Peter, I am now working on it...
By the way, I never activated 'Stop W10 Services' before.
* result *
  • First I applied your XXHighEnd-208e-X patch (although unrelated to the RD desktop issue I guess).
  • Then rebooted into normal OS: RD connection remained OK in Attended as well a Unattended mode.
  • Then activated 'Stop WS Services': RD connection remained OK in both modes.
  • Then de-activated 'Stop WS Services': no problem.
  • Then rebooted into Minimized OS.
  • Then noticed it is impossible to get the LAN up using the 'LAN On' button; nor is it possible play with the 'Keep LAN Services' setting on. It keeps asking whether I want to wait longer, but eventually I don't.
  • Playing goes well – and RD connections remains OK – with the 'Keep LAN Services' setting off, just playing from a stick.
So the behavior appears unchanged compared to yesterday's report.
Dennis
« Reply #7 on: October 02, 2017, 03:40:01 pm »
Dennis, a quick note : please do not edit posts like you did with this one, because I am waiting for your response (after your initial "working on it"), while you edited it in in the other post. I (or anyone) just won't see that (unless by accident).
« Reply #8 on: October 02, 2017, 03:41:29 pm »
I suppose it is totally obvious, but I don't see what "WS" services are ?
« Reply #9 on: October 02, 2017, 03:55:43 pm »
I suppose this works differently from what you expect;
The check for the LAN goes by means of checking whether the last file played (actually the track selected in the Playlist Area) can still be found. If not, the LAN is reported not to be there ... swoon
Sadly this is not a build-in feature and merely a kind of bug. I mean, when you don't have the LAN you also won't have an RDC connection, right ? Well, sort of, because when you Keep the LAN "not persistent" it shuts off when playback starts but RDC activity remains.So the bug in this case comprises of shutting off the LAN (in normal OS arranged for) while using RDC overrules that partly (as it seems).
Btw, the sheer fact that you try this (for its working) could imply some kind of pilot error I don't think of.
These should be the crucial settings :
Be in Normal OS
Load a track (or more) in the Playlist Area; select it.
Stop Desktop
Stop Remaining
Stop W10 (just because I use it like that myself)
Use Remote Desktop.
Keep LAN, Not Persist (the latter means it shuts off during playback, the former means it will not be cut off right from the start (the boot).
Boot into MinOS.
No need to test or report about Attended Playback. Only Unattended.
Can you now try this :
Go back to Normal OS again.
Make OSIsW10.tst active (you will understand what I mean) because it should imply the same siuation as with 2.07, regarding this.
Same settings as above.
Go to MinOS.
Now it works ?
« Reply #10 on: October 02, 2017, 03:57:13 pm »
So the 2.08e is for testing what happens with this Group Policy Message. I hope you can let me know when you are confident it will stay away, or is still there.
bodiebill
« Reply #11 on: October 02, 2017, 06:29:54 pm »
oops sorry, next time I will make a new post...
bodiebill
« Reply #12 on: October 02, 2017, 06:30:55 pm »
sorry, typo, it should have been W10 services :-|
bodiebill
« Reply #13 on: October 02, 2017, 07:08:06 pm »
Be in Normal OS
Stop Desktop
Stop Remaining
Use Remote Desktop.
Boot into MinOS.
Go to MinOS.
Now it works ?
It does work!
Actually, OSIsW10.tst already had the tst extension, so that means it was already active?
I could not resist also trying to rename OSIsW10.tss to OSIsW10.tst (and OSIsW10.tst back to OSIsW10.tss), and that also worked fine. Or am I messing things up?
Also, the LAN On button works now. Now you explained how it works, it seems logical that it does not work with a playlist loaded from a usb stick?
Thanks, Peter!
« Reply #14 on: October 02, 2017, 08:05:29 pm »
Hi Dennis,
Haha, yes. But you had this from your previous attempt with 2.07.
Not that I can follow really what happened now and why it now works fine.
Well, it should. But only if that USB stick is still in ...  Happy
OK, good. Problem solved. scratching
Have fun now !
PS: But still waiting on that Group Policy thing, because at this moment (2.08e) something is On which can be Off.
Page created in 10.104 seconds with 19 queries.
