July 01, 2025, 10:50:40 pm *
Author Topic: Upgrade Patch  (Read 5425 times)
« on: October 30, 2017, 09:00:23 pm »
In the past I have only applied the "new version patch" after reverting out of minimize and booting into the base OS. Is this necessary or can I do all this in  minimized with the OS loaded in RAM? Just unzip the patch over the 2.xx folder?
« Reply #1 on: October 30, 2017, 09:17:12 pm »
Hi Brian,
You surely can do this when in RAM Boot. But you'd need to do it all the time again after a boot.
So actually the answer is No.
But that ain't necessary either. Just boot into the BASE OS of concern, appy it there, check a few things - and boot into RAM OS again as if nothing happened.  Happy
« Reply #2 on: October 30, 2017, 09:31:57 pm »
Thanks!
