July 02, 2025, 01:41:59 am *
Author Topic: Safely remove hardware can’t be found  (Read 5354 times)
« on: March 14, 2018, 12:57:25 pm »
I am unable to locate the “safely remove hardware” icon in the taskbar. The only icons visible are Phasure Control panel & One drive not signed in.
I need it to eject the RAM OS disk after booting into RAM OS.
« Reply #1 on: March 14, 2018, 03:08:57 pm »
Hi Arvind,
Well well, you ask that pretty quick, right ?
... after a year or so ... Maybe yoy never rebooted.
haha
No. This is not needed. You can just remove it.
This is a bit different when you start accessing it via Drive D: ... for which you normally have no reason. However, access another OS via "Attaching" is and Drive X:, also goes with the procedure to de-attach it. This is your "eject".
The icon is not there because of MinOS in combination with Windows 10 - 14393.0. Say similar to the Taskbar mostly not working.
Kind regards and very good that you asked !
« Reply #2 on: March 14, 2018, 03:38:06 pm »
Actually I had been just removing it after booting, however due to the OS getting corrupt a week or so back, I was just wondering if it was due to my just pulling out the drive. Of course I know now that wasn’t the reason.
« Reply #3 on: March 14, 2018, 04:32:49 pm »
Ah ...
Well, this is a bit tricky, because as said, you could have accessed the SSD anyway but per explicit means (you'd need to do something with Drive D: in that case).
If you don't recognize anything of this, then I'd say it has been coincidence and an accident. A rare one though.
