« on: April 01, 2018, 06:42:44 pm » |
I really like to listen over and over to one track or one album so I’d like both of these features added. I hoped they would be in v2 already but it seems nobody asked for.
« Reply #1 on: April 02, 2018, 09:25:40 am » |
Telstar - of course nobody asked for that because it is in there since 0.5 whatever (just making up some version - but 8-9 years ago).  The [ A ] and [ B ] button do just what they suggest for a track. Repeating the album would be loading the album x times in the Playlist Area (this is quite harmless). Regards, Peter
For the Stealth III LPS PC : W10-14393.0 - April 1, 2020 (2.11) XXHighEnd Mach III Stealth LPS PC -> Xeon Scalable 14/28 core with Hyperthreading On (set to 14/28 cores in BIOS and set to 10/20 cores via Boot Menu) @~660MHz, 48GB, Windows 10 Pro 64 bit build 14393.0 from RAM, music on LAN / Engine#4 Adaptive Mode / Q1/-/3/4/5 = 14/-/1/1/1/ Q1Factor = 1 / Dev.Buffer = 4096 / ClockRes = 15ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = *20.69* (max *20.69*) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 3-5 / Not Switch Processors during Playback = Off/ Playback Drive none (see OS from RAM) / UnAttended (Just Start) / Always Copy to XX Drive (see OS from RAM) / Stop Desktop, Remaining, WASAPI and W10 services / Use Remote Desktop / Keep LAN - Not Persist / WallPaper On / OSD Off (!) / Running Time Off / Minimize OS / XTweaks : Balanced Load = 52 / Nervous Rate = 10 / Cool when Idle = n.a / Provide Stable Power = 0 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = Stable / *Custom Filtering* *High 3.72%* (16x) / Always Clear Proxy before Playback = On -> USB3 from MoBo -> *Lush^3* A: B-Y-R, B: W-Y & R-G* USB 1m00 -> Phisolator 24/768 Phasure NOS1a/G3 75B (BNC Out) async USB DAC, Driver v1.0.4b (16ms) -> B'ASS Current Amplifier -> Blaxius^2 A:B-R, B:B-R Interlink -> Orelo MKII Active Open Baffle Horn Speakers. ET^2 Ethernet from Mach III to Music Server PC (RDC Control). Removed Switching Supplies from everywhere (also from the PC).
« Reply #2 on: April 02, 2018, 04:35:13 pm » |
Telstar - of course nobody asked for that because it is in there since 0.5 whatever (just making up some version - but 8-9 years ago).  The [ A ] and [ B ] button do just what they suggest for a track. Repeating the album would be loading the album x times in the Playlist Area (this is quite harmless). Regards, Peter Remember I was using 0.4-1?  I'll tinker with A-B buttons. No problem with loading an album 2 or 3 times (once I sort out the errors - more tracks = more erorrs).
Tore
« Reply #3 on: December 26, 2020, 09:48:07 am » |
Hi Peter!
Is there a way to play a album in repeat 24/7 ? (i have new speakers)
I have tested to load the album x times but it do not work for me
Tore
Phasure Mach III, 12/24 core (Win 14393.0 on RAM-OS / controlled by RDC, / connected directly to music server / XXHighEnd 2.11 / Minimize OS / Engine#4 Adaptive / DB=4096 / Q1=10 / xQ1=15 / Q3,4,5=1 / SFS=0.69 max=140,19 /XTweaks = 35, 10, 0, 0, 0 / Straight Contiguous / Clock Resolution = 15ms / Scheme 3-5 (low/realtime) / Unattended) mobo USB3 port -> Lush^2 -> Phasure NOS1a B75 G3 -> Blaxius^2 , Crazy A monoblocs, Avantgarde Duo Omega
« Reply #4 on: December 26, 2020, 11:32:33 am » |
Hey there Tore,
Your options would be :
- Load the albums you want to play in the Playlist Area, and play them Attendedly.
- Look for a large track (like 60 minutes or whatever you want) and play that A-B via Unattended. Thus, A-B for a track just works for Unattended.
Best regards, Peter
Tore
« Reply #5 on: December 26, 2020, 02:42:14 pm » |
I have never loaded more than one album.
When i load one album over the first the first disappears
Tore
« Reply #6 on: December 26, 2020, 02:59:21 pm » |
Tore, then you should not load an album by means of double clicking it ... Just use Load or Drag or Open or whatever dozen means, but not Double-Click on the Cover in the Library Area.
Regards, Peter
« Reply #7 on: December 26, 2020, 03:00:35 pm » |
When i load one album over the first the first disappears So if you really have never done that, you also can't have worked with Galleries !! Anyway, you have been missing a LOT ...
Tore
« Reply #8 on: December 26, 2020, 03:29:21 pm » |
YES, that works  thanks, Tore
