July 02, 2025, 11:34:19 pm *
Author Topic: USB Dropping Out  (Read 4648 times)
« on: July 01, 2019, 08:04:04 am »
Over the last couple of days a problem has started where the USB connection between NOS1 and my music PC drops out "randomly". So with the music PC and NOS 1 switched on the USB connection stops working (i.e. the green light on the USB board in NOS 1 goes out). I then have to switch NOS 1 power off and back on again to re-establish connection. So far it has not happened when playing music. This problem has only started in the last couple of days and has not happened previous to that i.e. in the previous 2 months that I have been using my new 621 based PC. I have not made any changes recently so not sure why it has just started.
It would appear that it does not happen if I leave XXHighend software up and running but I have not left it long enough to be 100% sure. I will test that today/tomorrow by leaving XX running.
Any help or ideas would be much appreciated.
« Reply #1 on: July 01, 2019, 05:59:27 pm »
Hi Paul,
Focus on the connection of the usb cable, both ends.
It happens to me too, after I moved something etc.  In the end you  will have it right again and then it will stay right.
It is super sensitive.
« Reply #2 on: July 03, 2019, 11:09:59 pm »
Thx reseating the usb plugs seems to have solved it
P
