July 01, 2025, 04:14:45 pm *
Pages: 1 2 [3]  All
Author Topic: glitch at end of track  (Read 38787 times)
« Reply #30 on: March 23, 2012, 12:04:30 pm »
Ok, let's try to solve this. Remember, try ... Happy
Can you show me the CPU graph from that period of silence towards the end of the track ? (Attended)
In the mean time tell me what the Appointment Scheme is you used there, and what the SFS size is. Also, use 16/44.1 and tell me the Upsampling Rate.
Let's see further from there ...
samda04
« Reply #31 on: April 01, 2012, 11:34:11 am »
I keep on trying with several settings (all attended). The problem is only there with high resolution playback, so I test it with these (flac) files, native input = 96 Khz. My output-sample rate is 96 Khz, the dac's standard (usb).
The good news is that I found glitch free settings on my system:
- Proc. Core App. Scheme = 2
- PlayerPrio = Normal
- ThreadPrio = RealTime
- Clock Res. - nothing
- SFS setting = 36
The setting "PlayerPrio" set it to Normal instead of Realtime is crucial to give glitch free playback, definitely. Switched several times, glitches (dis)appears again.
But after reboot, and try this again, both settings (normal/realtime) played glitch free (??). Also, set proc. scheme app. to scheme 2 gives better dividing over 4 cores, maybe this helps too (see graphs). But today I saw another graph, more divided  to all cores (with same No app. setting).
So everything seems to be solved for now. Test results gives not always the same results, so sometimes it's hard to conclude the real cause of the problem. But generally, it's clear where it came from now: combination of settings as describes above.
Version: 0.9z-6-1. Settings: Engine 4, Special, buffer 96, Q1=10, proc. core Appointment Scheme 2, PlayerPrio Normal, TreadPrio RealTime, clock res. Nothing
System: Windows 7 Ultimate x64 SP1, Intel core i7 2670QM, 8gb memory, OCZ Vertex 3 ssd, Pink Faun 3.24 24/192 dac with usb-module 24/96, Pink Faun D-Power 2x180 amp, B&W 803 SII speakers, modified by Triple M Audio, cabels LS & Interlinks by Tr M Audio.
« Reply #32 on: April 01, 2012, 02:48:17 pm »
Two things I can see :
1. The speed of your disc subsystem is too slow.
(btw, how is that SSD from your sig related ? ... this is a laptop, right ?)
2. I assume I see peaks of the track parts which load. Well, they should reach 100% and they don't.
Are you sure your CPU isn't limited (to 40% or so) ?
See below picture for how it should look like. Those peaks to the top should be there.
Might you post more graphs, please take care that the refresh frequency is set to "High".
Anyway, good that you achieved something !
« Reply #33 on: April 01, 2012, 02:54:33 pm »
Also, you don't seem to play in Straight Contiguous Memory Mode;
That won't make things faster ... no
samda04
« Reply #34 on: April 02, 2012, 08:59:28 am »
My disc subsystem is connected by high-speed usb 3, also the processor speed is unlimited. The processor don't need to reach 100%, peak-loads are simply not high enough for the i7 processor, that's what I assume. My previous laptop reached 100% indeed, but that was a dual core with much less specs.
samda04
« Reply #35 on: April 02, 2012, 09:06:20 am »
Straight Contiguous Memory Mode is on now, will test it later.
« Reply #36 on: April 02, 2012, 12:55:49 pm »
Haha, then you assume wrong. So, when we can agree that your cores don't reach the 100%, then there is 100% sure a problem.
I'm talking XXHighEnd of course, and not some random other program.
samda04
« Reply #37 on: April 02, 2012, 01:28:19 pm »
Please tell me what to do to make it peak to 100%. I set in Processor Powermanagement the min-max processor state both to 100%....Always the full clockspeed (and turbo when necessarily).
« Reply #38 on: April 02, 2012, 01:43:11 pm »
Good question. Wrong scheme ? something with battery vs. mains connected ? BIOS ? some scheme from the particular brand somewhere ?
Btw, I assume the laptop is mains connected ? when not, chances are fair that it won't even allow itself the 100%.
Maybe you can deliberately squeeze down the max and see whether it makes a difference ?
In the end things can get more complicated, like for example the memory (bus) being so slow that the cpu is always waiting.
samda04
« Reply #39 on: April 02, 2012, 03:33:25 pm »
As said, any program that needs a full load of the processor will work, up to 100% load.....inclusive turbo-boost (quad-core, 2,8 Ghz). Really a fast processor. Only XXHighend won't do that 100% peaks, if needed, apparently. But the most important is it works, without those glitches, and I'm happy again!
samda04
« Reply #40 on: April 14, 2012, 09:11:08 am »
100% processor-load was all right all the time....Just changed the refresh rate of my graph to see this  very happy
By the way: using Straight Contiguous Memory Mode requires me a Windows reboot, on each first use of XX. Is this normal?
« Reply #41 on: April 14, 2012, 10:18:09 am »
No. That means it just doesn't work at all I think ...
Look here : http://www.phasure.com/index.php?topic=1547.0
If that doesn't help you, search for "privileges" and there will be quite some more. Ok ?
Pages: 1 2 [3]  All
