July 01, 2025, 10:59:21 pm *
Pages: [1] 2 3  All
Author Topic: glitch at end of track  (Read 38795 times)
helicon
« on: July 22, 2010, 12:40:39 am »
Hi.
Innstalled 0.9z-2 this evening. Sounds better:)
But at the very end of a song, there is a little glitch, and this is very annoying.
use engine3, all q to 0.
I am new to xxhighend, used foobar before, so do not understand how everything works.
thanks, Per Arne, norway
« Reply #1 on: July 22, 2010, 05:48:29 am »
Hi there Per Arne,
Before proceeding with this, can you tell me what you used to rip the albums which exhibit this ?
And what is your "Split File size" setting (Settings Area) ?
Thank you - and welcome of course !
helicon
« Reply #2 on: July 22, 2010, 04:22:34 pm »
I don`t think it is because of any ripping prossess. I used engine 3 in earlier versions, and it worked just fine.
my split is 100mb
« Reply #3 on: July 22, 2010, 05:51:34 pm »
What is your "DAC Needs" setting ? (24 or 32)
And what do you use for ripping ?
Please answer my questions, or otherwise I'm in the blind.
helicon
« Reply #4 on: July 23, 2010, 02:28:00 pm »
dac needs settings are 32.
Use ripstation micro for ripping
« Reply #5 on: July 23, 2010, 02:44:36 pm »
Ah, thank you very much.
Ok, can you recognize that you NEVER hear such a glitch in the middle of a track which is, say 4 minutes or longer ?
« Reply #6 on: July 23, 2010, 02:54:01 pm »
In the mean time ... did you try the various Core Appointment settings ?
Please note : if that helps, I am not saying "so use that setting in the future", but I need to know it in order to find what can be the matter. So, as I think now this must be related to your system and settings somehow, or otherwise I would have dozens of these complaints, and I don't have any. It *is* recognizeable though. One thing which springs to my mind : maybe your disk where the music is on spins down too early. IOW, it has to spinup at a next track, but might do that just too late.
Many other things can be the matter, and it's a bit of a difficult subject. In either case you can always blame me. yes
helicon
« Reply #7 on: July 23, 2010, 03:22:39 pm »
yes, it glitches in the middle of a song.
You may be right, it can be my system?
I experienced that xxhighend uses more cpu than other mediplayers I have tried.
But, can it help to innstall one of the earlier versions?Happy
« Reply #8 on: July 23, 2010, 03:32:24 pm »
That may help, because things change all the time. But it wouldn't be the solution.
But about your CPU ... It really shouldn't be more than 2-4% with 32/192 playback. If you see more, something may be wrong in that area.
What processor/PC do you use ?
Soundcard/DAC ?
But hey, since you now tell that it's in the middle of a track just the same, lower the File Split size and you will see that it helps. Maybe set it to 70, or to 30 to test whether it really matters, and then go up again.
Don't forget the Core Appointment settings, because they are the most crucial in an underpowered system.
If nothing helps, try Q1 at 4 or so. Maybe higher. It will change the sound as well, but for now it's only for testing. Ok ?
helicon
« Reply #9 on: July 24, 2010, 07:27:01 pm »
2gb ram, 2.20ghz intel celeron, vista 32
what is this core appointment setting? Should I set it to "sceme 1"? I used "high" on player prio, still glitches.
the q`s must be at 0, because of sound quality, that is why we use xxhighend, because of the sound Tongue
but tried also setting the file size split to 30 and 70, MORE glitches? wacko
« Reply #10 on: July 25, 2010, 05:54:45 am »
More glitches ? ah, that's good. That prooves that something's defenitely wrong. And it is your Celeron ... sorry If one processor can't do these things it is the Celeron. You could try Scheme-3 though, set the Player Prio to the lowest possible and the Thread Prio to Real Time (maybe less if you run into other throubles because of this). And best for SQ is to use Unattended Playback.
When it helps, don't forget to set back the Split File size.
helicon
« Reply #11 on: July 25, 2010, 08:21:59 pm »
Hi Peter!
did what you told me to, and it works.
I will not call you a genies yet, but a highend cd player for 72euro, that`s makes me itch my head.Happy
« Reply #12 on: July 26, 2010, 09:53:51 am »
Haha, good. And thanks. Happy
samda04
« Reply #13 on: March 13, 2012, 09:46:10 am »
Since I have a new laptop (Intel core i7) I hear glitches as well, at the end of each track. As well, it says "End of track" again....sometimes, sometimes not (nothing of these problems on my old laptop with same settings). New: can't set Processor Core App. Scheme (says "Undermol"). Could that be the reason?
Version: 0.9z-6-1. Settings: Engine 4, Special, buffer 96, Q1=10, proc. core Appointment Scheme 2, PlayerPrio Normal, TreadPrio RealTime, clock res. Nothing
System: Windows 7 Ultimate x64 SP1, Intel core i7 2670QM, 8gb memory, OCZ Vertex 3 ssd, Pink Faun 3.24 24/192 dac with usb-module 24/96, Pink Faun D-Power 2x180 amp, B&W 803 SII speakers, modified by Triple M Audio, cabels LS & Interlinks by Tr M Audio.
« Reply #14 on: March 13, 2012, 09:50:00 am »
It can, because the Appointment Schemes divide tasks better.
But I wouldn't be too sure about it ...
Did you also change OS ? if so, from which to which ?
Do you now use different music storage means ?
PS:
Let me know (per email) when you need a new Activation Code.
Pages: [1] 2 3  All
