May 09, 2025, 08:49:20 am *
Pages: 1 [2] 3 4 5  All
Author Topic: SFS Privileges  (Read 62708 times)
« Reply #15 on: September 19, 2011, 08:10:21 am »
Paul ... the Off button ...
« Reply #16 on: September 19, 2011, 12:47:27 pm »
Hi Peter - durgh  unhappy  I never noticed that before. Anyway I made a few more checks this morning and what is happening is clear now but I still have a problem: -
Problem 1 - The original "as supplied" W7 SP1 partition works with SC set to 420 engine 3 starts and grabs about 4.2Gig of memory. 420 is about the max my system will do with SC. As you pointed out Peter whilst Engine3 remains loaded the amount of SC will remain the same (regardless what SC is set to) until Engine3 unloaded again. This is not much of a problem now that I know what is happening.
Problem 2 - On my new "vanilla" W7 pre SP1 build XX works exactly as above (no real surprise) but XX can only run on SC with an SFS of 15 and Engine3 does not seem to (be able to)  grab any more memory. Both Administrator and me are listed in the allowed to "lock memory" privileges.
So any ideas as to why XX cannot grab more memory for SFS on my vanilla W7 Ultimate install would be much appreciated. With the privileges OK and plenty of system resource (there is loads of free memory) I have run out of ideas.
All the best
P
** UPDATE **  AH HA - JUST TRIED ON ON VANILLA W7 PRE SP1 XX WORKS OK WITH SC AND SFS AT 210 (STILL NOT AS MUCH AS 420 ON THE PRESP1 INSTALL) WITH THE OS MINIMISED SO SOMETHING ELSE MUST BE GRABBING MEMORY WITH "FULL OS". ANOTHER SMALL STEP FORWARD.
** UPDATE NUMBER 2 ** - I HAVE ALSO TRIED VANILLA W7 PRE SP1 ON THE DUAL BOOT SYSTEM AND IT EXHIBITS EXACTLY THE SAME CHARACTERISTICS AS DESCRIBED ABOVE FOR VANILLA W7 ON THE STAND ALONE DISC. SO DUAL BOOT DOES NOT SEEM TO BE A PROBLEM AT THIS STAGE.
« Reply #17 on: September 19, 2011, 01:06:25 pm »
To you (and boleary undoubtedly experienced the same) it seems that the first attempt fails, a next with Mixed Contiguous (or Mixed alone) works (this would be true) to next see it happening that Straight now works too. But this last step is a "fake" one ...
I don't think the last step is a fake one here. Once I'm in SC by using the above described procedure, I'm able to change the sound by changing the SFS in SC. So, just last night I was listening to the difference in SFS of 200 and 350. Because the lower size has more of an edge but is more clear or articulated I reduced from 350 to 315 and had the best of both, though I'm not sure whether its album or track specific. I mean it could be that some albums play better with slightly different settings.
Because I was able to hear these changes, I don't believe that the last step--switching from MC to SC is fake over here. I do have to do this every day when I turn the PC on or I can't use SC.
One more thing, using the higher SFS has completely removed a particular edge I've had in every version of XX including Z-6, though Z-6 is so much better than everything I didn't know that edge was still there untill I started changing SFS settings last night. Hope this makes sense.....
« Reply #18 on: September 19, 2011, 01:15:02 pm »
Hey Boleary - I have been looking at resource monitor and I can see engine3 grabbing memory (in SC) when fired up but the amount of memory taken does not change until engine3 is unloaded from memory (at which point all the memory reserved is released again). So certainly for my system Peter would appear to be correct.
« Reply #19 on: September 19, 2011, 01:21:16 pm »
I'll check whats going on using the resource monitor when I get home this evening. Hope you get that other speaker going soon!
« Reply #20 on: September 19, 2011, 01:30:14 pm »
Paul, it is obvious to me that with the OS Minimized XX can take more SC memory. So, nothing strange there.
Can it be so that the differences in the two situations are about Pro (more SFS) vs. Ultimate (less) ?
If so, things woule be a kind of logic to me ... (but I'd have to dig further first).
« Reply #21 on: September 19, 2011, 01:43:21 pm »
Minimized does not give me more SC. (50) (4GB RAM)
Home Premium
« Reply #22 on: September 19, 2011, 04:43:34 pm »
I am not using Ultimate but Pro and I can get it up to 500 (including fresh reboot) without a problem. 510 was too much but if once played unattended and minimised then even 550 was not a problem but rebooting will this then give the SFS error again...
I use this PC with a clean OS (not any update whatsoever) and for XX only.
« Reply #23 on: September 19, 2011, 08:17:14 pm »
Hey Peter,
According to your signature you are running W7 Ultimate and getting SFS of 430 with 8Gig ram. I am running W7 Ultimate with 12Gig ram with max SFS 210 ???
P
« Reply #24 on: September 19, 2011, 11:26:56 pm »
I'm just more demanding ...
IOW, no clue at this time.
(but the 430 is the normal figure, really)
crisnee
« Reply #25 on: September 20, 2011, 02:46:43 am »
Just to add to the confusion, I'm running W7 with Sp1 and updates, offline and all that implies--basically only use the pc for audio, but attended, OS NOT minimized, Engine 3 shut off, with 300 SC, no problem.
I'm afraid to try minimize OS and Vanilla-izing the system because it sounds great as is and I don't want to incurr problems so that I can't listen to it.
Did anyone notice that I said it sounds great with SP1? It seems to sound much better (sweeter--in a very good way) then the previous incarnation of XX, with a slightly clearer soundstage and better detail--which usually doesn't go along with something like "sweeter."
-Chris
« Reply #26 on: September 20, 2011, 08:40:16 pm »
So now I have installed a clean vanilla W7 Pro (pre SP1) on a clean formatted disc. Install of o/s bog standard again and installation of XX no problems. So now running on W7 pro pre SP1 (stand alone disc) exactly the same as vanilla ultimate I can get about 210SFS with full o/s and 260 max with minimised o/s.
Very curious the original install of W7 Pro Sp1 gets SFS well over 400. I have the resources available but somehow I am being prevented from using them. Task manager shows lots of free memory not being used by any other processes.
** Update ** on vanilla W7 Pro XX with SFS 410 now seems to be working and reliably - it seems that if the very first thing I do after start up is run XX in at 410 SC it seems OK even if you then reboot. But going back to W7 Ultimate on 2nd boot partition does not work reliably at all with SC. And a stand alone W7 Ultimate vanilla I could not get above SFS 210 whatever I tried although it was more reliable than the 2nd boot partition install.
Very strange - I can not even begin to imagine what is going on.
P
« Reply #27 on: September 21, 2011, 09:04:27 am »
I can Paul. It will be tough to copy all what you experience out there, so I must work from theories (and first make them, haha). But you are a great help.
Don't expect me to make something out of this, but when I see the light, I will.
« Reply #28 on: September 23, 2011, 08:28:17 pm »
Well not entirely true i guess.  unhappy
I started all over and I did use Peter's comment about the way OS minimise should be used http://www.phasure.com/index.php?topic=1810.msg18425#msg18425
Also i use the settings from Boleary.
SFS  Straight Contiguous can be used overhere with 140!  Happy
Like to say that ticks/clicks are gone now.  Happy  SFS? or Boleary's settings? Does not want to go back
Happy Happy
« Reply #29 on: September 24, 2011, 01:01:48 pm »
Hi - back to square one. I have changed nothing and now I am struggling to get SFS to anything on SC following a reboot. I was running on SFS = 400 and provided I left engine3 in memory it was reliable.
Now the best I can achieve is to increase gradually SFS by starting at SFS = 0.2 (that is the only way I can run in SC) start to play a track then click OFF (ie Engine3 out of memory) then increase SFS by 2 (and no more or I get error messages) and keep repeating this process but I can only get up to around SFS=30.
This is on W7 Pro vanilla pre SP1 and a simple install just for XX and music (music on separate disc). The only thing I do notice is that the volume control does not work (one click brings up the green bar which does not disappear no matter how long you wait). When I can set SFS volume works OK.
Nothing for it but a complete new install as I cannot think of anything else to try. I did install everything and run XX before using the minimise o/s function so I do not think that is the problem.
Privileges are set OK.
GGGrrrrr
P
