July 01, 2025, 08:18:45 am *
Author Topic: HDCD Decoding Problem  (Read 24453 times)
Eric
« on: October 15, 2012, 11:14:45 pm »
I get this message in the following situation.
I start a HDCD track. I stop playing the track. I start the track again.
It only occurs when I have HDCD decoding activated.
Eric
« Reply #1 on: October 16, 2012, 08:03:36 am »
Hmm ... Eric, does it go away when not using the Playback Drive ?
Eric
« Reply #2 on: October 16, 2012, 09:46:05 am »
Yes this problem goes away when I don't use the Playback Drive.
Eric
« Reply #3 on: October 16, 2012, 10:16:45 am »
Ok, something to solve.
Thanks Eric.
« Reply #4 on: October 20, 2012, 05:29:07 pm »
Eric,
You really have to tell me more because the problem doesn't occur here. So my sequence :
Press [ C ], play an HDCD track, press Stop (or Pause) and Play again. All OK ...
Eric
« Reply #5 on: October 24, 2012, 02:26:22 pm »
I follow the following steps:
.Boot up to minimized OS
.Load 1 HDCD track
.Play the track to the end in  Attended mode
.Click Play to replay the track  ====> Error
Same happens if I Stop the track in the middle and Play again.
I hope this helps.
Eric
« Reply #6 on: October 29, 2012, 06:25:53 pm »
Eric - no dice here. Whatever I try (including following exactly what you told). To be safe I also started with Normalizing the album (of that one track in the playlist). That makes things different for sure, but it keeps on working ...
Sorry,
« Reply #7 on: October 29, 2012, 07:07:18 pm »
I'm having problems playing HDCDs too. But I think it's only with HDCDs that have the 'real' Peak Extension HDCD processing encoded into them.
BTW, it doesn't matter if PE is switched on or off in XX - the error message still appears.
« Reply #8 on: October 29, 2012, 07:11:01 pm »
To be clear, my problem is different to Eric's. I cannot play HDCDs, period.
They play fine with HDCD deactivated in XX. But I get the error message when HDCD is activated in XX.
« Reply #9 on: October 30, 2012, 08:04:02 am »
Noteworthy because I think you are the first ...
« Reply #10 on: October 30, 2012, 08:06:33 am »
Eric,
Can you email me your SettingsPreset.XXSI file ? It's in your XX folder.
« Reply #11 on: October 30, 2012, 08:11:55 am »
Mani,
Can you FileMail me such a track please ?
And do you have some info on this ? I am not aware of such an option ...
Is it denoted on the CD or something ? Is it an option on the PMII ?
Thanks and sorry to be dumb somewhat ...
Eric
« Reply #12 on: October 30, 2012, 08:38:24 am »
there is no SettingsPreset.XXSI file in the folder XXHighEnd-09-z7-5.
However there is a SettingsReset.tss file. You don't mean this, do you?
Eric
« Reply #13 on: October 30, 2012, 10:33:46 am »
Eric, I am doing this by heart ... Look for anything with the extension .XXSI
Eric
« Reply #14 on: October 30, 2012, 11:17:33 am »
Ah, I see.
I found PresetLoader them and sent it to you by mail.
Eric
Page created in 0.104 seconds with 19 queries.
