July 01, 2025, 08:26:40 am *
Author Topic: 0.9z-8-3a PC freeze  (Read 14063 times)
« on: March 16, 2013, 04:49:35 pm »
With the previous version i talked about that the pc sometime's stops en freezes. That got better when i set the balanced load higher. From 43 to 60.
Now with this version i still have the stops. What happens is this.
XX stops playing and i still can get the mouse moving around. But when i hit a button like STOP or another the pc freez. And a reboot is needed.
I have entered the log's maybe you can see something.
PC at 3.4 GHZ and 38\40 degrees
* X3-20130316-152755.log (13697.66 KB - downloaded 617 times.)
* X3PB-20130316-160841.log (302.79 KB - downloaded 600 times.)
* XX-20130316-162320.log (3.48 KB - downloaded 560 times.)
« Reply #1 on: March 16, 2013, 06:29:43 pm »
Gerard,
Nothing to be seen in the log files. But if you have your logging on it can be the reason within itself (way too large).
« Reply #2 on: March 16, 2013, 06:31:40 pm »
Gerard,
Neh just have set it on for the logs... Maybe a fresh W7 just to be sure.
Music stops in the middle of a track.
Thanx anyway...
« Reply #3 on: March 16, 2013, 06:41:21 pm »
But before you think this is XXHighEnd or the OS ... I don't think so.
Didn't you say this was about setting your CPU's frequency too low ? dntknw
« Reply #4 on: March 16, 2013, 06:49:13 pm »
Yes first i thought is was but now i have it at 3.6 GHZ. So that could not be it.
With the previous i had it with a too low balanced load setting.
 scratching
And since i do not hear anybody else about this.
« Reply #5 on: March 16, 2013, 06:58:19 pm »
Hum... Allow me Wink I rarely listen to many songs at a time, but yesterday I decided to put 4-5 songs and play unattended. XXHE was activated (red title, red border cover art, no UNDEMO). That was checked after the stop happened.
It happened once. After I played series of 3 songs with a little higher Q1 (14) and all seemed fine.
When it happened, I had: Q1 = 6, Q1x = 1, SFS = 12, Xtweaks OFF, the rest equal to my sig...
« Reply #6 on: March 16, 2013, 07:08:01 pm »
Hey Alain,
Was it a stop or also the freez after hitting a button on xx?
« Reply #7 on: March 16, 2013, 07:21:41 pm »
Yes, I hope it is clear that I responded to the freezing alone. The stops is another matter (and undoubtedely XXHighEnd settings etc. related).
« Reply #8 on: March 16, 2013, 07:40:22 pm »
Hi Gerard,
Like Peter mentionned, it was just a stop. No freeze...
« Reply #9 on: March 16, 2013, 07:43:11 pm »
Ok!
What is your setting in the memory setting in the BIOS? 2133?
« Reply #10 on: March 17, 2013, 08:44:19 am »
Gerard,
1333 IIRC. But I am not using that PC. Anyway, just the default.
« Reply #11 on: March 17, 2013, 09:58:58 am »
Gerard,
Thanx!
« Reply #12 on: October 09, 2013, 09:52:20 pm »
Ok i got this after a lot of trials.
I have read on the internet that sometimes Dram memory packs can cause this when set to a manual setting.
You have to use one of the XMP profile settings instead.
After one week not a single one anymore.
 rofl ok
