July 01, 2025, 06:59:33 am *
Author Topic: Peak Extend - revisited  (Read 5662 times)
« on: June 26, 2014, 12:57:21 pm »
So, who's still been using this recently? I know it isn't compatible with the new Custom filter, but I just wondered if anyone had been using it with AP.
Overall, I think it's a great idea - to prevent overs as a result of the filtering, even if the source material itself has no clipping. But PE seems to have fallen by the way side.
Just wondered...
charliemb
« Reply #1 on: October 16, 2014, 02:13:55 am »
I still use it with ArcP.  Yes, I've heard a difference.  It doesn't come into play that often if you don't use it, but playing with it on is the safer way to go,  IMHO.
July 2019:
