May 09, 2025, 09:30:49 am *
Author Topic: Looks Like I've Screwed Up Something with the 2.01 Install  (Read 25038 times)
Jud
« Reply #15 on: June 03, 2015, 06:56:59 pm »
Ah ...
What about setting the Scaling smaller ?
If you set ity to 1.7 it will be the same as it was (1.186).
Will that affect Remote, or different settings?
Actually - This *is* set to 1.7, I just checked.
So I tried 1.5.  Everything looks exactly the same, no change at all.
« Reply #16 on: June 04, 2015, 08:10:07 am »
oops
You are correct about the 1.7. The old one was 1.4.
But no difference at all ? hmm ...
« Reply #17 on: June 05, 2015, 02:23:36 pm »
- Minimized OS, unattended: Starts fine but within ten seconds the volume stops completely.  Since there's no UI I don't know whether it's stopped playing or is still playing but no volume.
- Minimized OS, unattended off: This is perfectly OK until I try playing unattended for the first time.  Then all subsequent attempts to play with the UI showing prior to a reboot don't work.  Playback won't start, and there is an odd thing going on with the UI where there's a sort of black "phantom loading progress bar" that progresses from left to right near the top of the XXHE UI.
Hi Jud,
I wondered ... are you (still) able to mimic this at will ? If so, how ?
I saw it myself but for the life of me I can let it happen any more. It is as if this happens right after an install only. At least that is where it happened to me and I recall something like having problems with it after each boot.
Of course I now like to solve it, but ...
Jud
« Reply #18 on: June 05, 2015, 07:00:41 pm »
Hi Jud,
Hi Peter -
I'll check tonight if I have time, otherwise in the next couple of days.
Jud
« Reply #19 on: June 06, 2015, 01:55:15 am »
Hi Jud,
Hi Peter -
Answer unfortunately is still yes.  As bar on, sound cuts out in ~10-12 seconds.  Off, it stays on as long as I like.
