July 01, 2025, 10:14:05 pm *
Author Topic: Those with Tidal ...  (Read 7117 times)
« on: June 10, 2019, 12:45:13 pm »
 … Do you notice too that when you don't enter an * to the Artist Name for searching Artists, you don't get a result any more ?
I did not look yet what's happening in the code, but point is that as far as I know I did not change a thing. And suddenly since somewhere 2 days ago, nothing is found when not adding the *.
« Reply #1 on: June 10, 2019, 01:32:59 pm »
You’re spot on it works adding * to the artist name. The only issue is that the cover art does not show, until I select the particular album from the 1st pane in XXHE.
« Reply #2 on: June 10, 2019, 02:44:43 pm »
Hi Arvind,
But it is not meant to work like that. And for sure it didn't a while ago. So since when is this, do you think ?
If you would ask me, I would say "since 3 days".
« Reply #3 on: June 10, 2019, 03:11:41 pm »
Since the 6th of this month I stopped getting any Tidal search results while entering only the artist name.
coliny
« Reply #4 on: June 10, 2019, 03:58:41 pm »
I noticed that * needed in artist name yesterday. Previous Tidal download was a week ago and did not need * then.
Colin
« Reply #5 on: June 10, 2019, 07:37:13 pm »
Thank you VERY much guys. I would have been searching for that needle in the haystack which just isn't there.
Quite a stupid Tidal change.
« Reply #6 on: June 11, 2019, 02:20:48 pm »
So Yes, Tidal changed something. It is solved for the next version.
For now, don't forget to add the * in the field for Artist Name. But obviously, mind the Result which now is "wildcarded". See second album in second picture below.
