July 01, 2025, 05:25:36 am *
Pages: 1 2 [3] 4 5  All
Author Topic: Review of Nicks Tweeks  (Read 71841 times)
« Reply #30 on: December 05, 2012, 12:42:50 pm »
No problem at all Stanley. You know !
« Reply #31 on: December 05, 2012, 07:45:16 pm »
... I would particularly recommend that Mani and Brian give 11c a go as we all have the same model of Mobo.
[11]c.   Disable all devices not used for Music in  Bios (Mobo USB, Sound card, COM ports etc)
Nick, did you mean enable here? I suspect you did as you mention that you were surprised. Anyway, let me know.
Cheers, Mani.
« Reply #32 on: December 06, 2012, 09:22:03 am »
I didn't dare to ask, because I felt a bit stupid about it. But to me it seems that Nick tries to say that when a device is disabled in the BIOS it should also be disabled in Windows.
But if Nick is not saying that, I will. Wink
PS: This is fairly new stuff, and 4 weeks ago I wouldn't have said such a thing.
« Reply #33 on: December 06, 2012, 09:53:45 am »
Hmmm...
In my office I use a PC with an i7-3770K CPU. The BIOS allows quite a lot of configuration. If I turn off all mobo USB devices in the BIOS (which I have), then no mobo USB devices show in Windows' device manager, i.e. you can't shut the devices off in BIOS and in Windows as there's simply nothing to shut off in Windows any more.
EDIT: I need to learn to read Nick's post more carefully. The blue text is what has changed from his original list. So yes indeed, Nick used to suggest shutting devices off in the BIOS but has recently found that keeping them on and shutting them off in Windows instead is better.
« Reply #34 on: December 06, 2012, 10:11:26 am »
Haha Mani, which is almost as confusing. But you are correct, when I read it yesterday (I now recall) that I read it the same. But let me rephrase please :
Nick used to suggest shutting devices off in the BIOS but has recently found that keeping them on in the BIOS and shutting them off in Windows instead is better.
Assumed that we talk about devices which would disappear from the Devices List when shut off in the BIOS (which sounds logic to me) then the next logic could be that because they are not there you can't disable them, so it is better to have them there so they can be disabled. This, assumed that when they are not listed, they are NOT disabled.
*If* this matters in the first place, I'd say that after disabling them in Windows, they can be disabled in the BIOS afterwards. This then may matter (SQ) additionally.
« Reply #35 on: December 08, 2012, 02:26:32 pm »
Hey Nick, was traveling all week and will give your latest suggestion a try today or tomorrow. I know I have just about every device shut off in my bios. Should I turn everything back on?
Right now I cannot imagine my system sounding better.
But I've been here before only to be amazed "again" hanging out with you guys......!
Brian
« Reply #36 on: December 09, 2012, 10:21:21 am »
Mani Peter hi,
I think you have picked up what I was suggesting correctly but just to confirm.
For a long time my "standard" PC set up disabled unused devices in BIOS. These include mobo sound card, USB, serial port, additional SATA controller types and LAN cards.
I was messing about with device settings in Device Manager and noticed a very slight I improvement in sound turning some disabled devices back on. This got me thinking if this happens at the OS level what about at the hardware level ?
So what I am suggesting in the update to the tweaks is:
A) In BIOS turn ON mobo sound card, USB, serial port, additional SATA controller types and LAN cards.
B) When these devices are turned on in BIOS  go into Device Manager and disable each of them.
Take a listen. In my case with the asus x79 mobo a whole layer of hardness and sibilance just went away  grazy You may find that LAN card back on in BIOS is a bit "accurate" sounding but after trying listening to LAN  off / on a few times, for now I am sticking with LAN on.
Cheers Nick.
Update I meant to say I was sticking with LAN ON in bios in the last line (now edited to say "on").
« Last Edit: December 09, 2012, 11:21:28 pm by Nick » Logged
« Reply #37 on: December 14, 2012, 11:06:36 pm »
My computer knowledge is limited. Where in device manager do I turn off, "serial port, additional SATA controller and Lan cards." There is nothing in my "System Devices" in Device Manager that identifies these. Thanks.
Stanray
« Reply #38 on: December 17, 2012, 01:15:05 pm »
/quote]
First back up your music drive (you proberbly don't want to re-rip 100s of CDs).
Then from there I would try to add a second partition to the music drive. I would make it at least 20gb so windows does not run out of space. Often you can add a partition and not lose the data on the drive but it's not guaranteed which is why you must back up your music.
Install windows on to the new partition and then install XX on the music drive either in the new windows partition or the partition where the music lives.
This should give you all of your OS music and XX on the same single physical HDD.
Hope this helps,
[/quote]
A question to avoid mistakes: This second partition on the music HDD needs a drive letter to be allocated.
When I attribute it f.i. the letter "G:" and install W7 and XXHE on it, what do I do next?
The former HDD with W7 and XXHE, the "C:" drive, will have to be disabled. Do I then rename new "G:" to "C:" to have a proper boot?
Thanks
Stanley
« Reply #39 on: December 17, 2012, 02:10:31 pm »
Stanly,
I can't exactly follow (didn't take much time for that either) but if you are talking about the situation that your OS drive now has become G: ... do not try to rename that to C:. Too much is dependent on it and you may run into errors you can't solve. So, just let it remain G:. There is no problem with that, except you can't use G: for something else anymore.
If this is your situation at all ...
Stanray
« Reply #40 on: December 19, 2012, 01:00:11 pm »
Stanly,
Thanks Peter,
Yes that was what I was trying to ask: does it matter that the OS is on "G" or on anything but C: for normally it is on C:.
Possibly a trivial question, but I wasn't really sure.
Stanley
« Reply #41 on: December 23, 2012, 02:54:18 pm »
Not sure why my last post here didn't get a response but that's okay, went to the doc and, despite what you may think, he said I don't have the coodies!
Anyway , yesterday I had the time to sort this out, I enabled all devices in my bios and ,voila, all the devices talked about before (LAN, Serial Port, etc.) suddenly appeared in Device Manager. The SATA controllers were a bit un-nerving cause I was afraid I might disable my OS drive! However I managed to discover the "location" tab for the drive which identified the SATA controller # it's connected to. After enabling the devices in the bios I disabled them in Device Manager. I got what appears to be a nice bump in SQ. Seems to have a blacker backround, more relaxed highs. Will give it a week or so of listening to be sure. Again, thanks Nick!
« Reply #42 on: December 23, 2012, 05:25:55 pm »
Okay, sorry about that. But at least I did not understand why you weren't seeing anything. But please combine it with my earlier post just about how you solved it : there's nothing to shut off - because not visible - when it's shut off in the BIOS. But I guess you didn't get that ? Not that it was layout *that* explicitly ... nea
« Reply #43 on: December 23, 2012, 06:15:52 pm »
Lets just say, for too many reasons to name, we over here are a bit slow, and at times, more so than others.  Happy
Just reread the HPET timer thread; it looks like there will be some more significant tweeks coming our way....perhaps wrapped in a bow under the tree????
« Reply #44 on: December 23, 2012, 06:35:03 pm »
You can bet on that ... Too much
