July 01, 2025, 04:59:18 am *
Pages: 1 2 3 [4] 5  All
Author Topic: Review of Nicks Tweeks  (Read 71834 times)
« Reply #45 on: December 23, 2012, 08:14:47 pm »
Not sure why my last post here didn't get a response but that's okay, went to the doc and, despite what you may think, he said I don't have the coodies!
Brian hi,
Sorry for not posting a reply, I have had a touch of "man flu" this last week and spent days in bed unhappy.
Sounds like you found the right settings in device manager, pleased to hear that the results are sounding good. I have to say it was not what I was expecting when turning devices back on in bios.
The HPET timer tweak seems to work very well on our Asus mobos, well worth a play to see what you think.
« Reply #46 on: December 23, 2012, 08:40:57 pm »
... and next Disabled them in Windows.
Correct ?
« Reply #47 on: December 23, 2012, 10:34:39 pm »
Correct ?
The answer better be yes.  Happy
« Reply #48 on: December 23, 2012, 10:49:35 pm »
That's a yes guys,
Turned on in bios
Turned off in windows device mgr.
« Reply #49 on: December 24, 2012, 09:52:01 am »
Switching off in Windows gives good SQ here. Being able to switch the LAN on/off is very user friendly as I rip files on another PC and transfer over the network then switch the LAN off for listening.
« Reply #50 on: March 01, 2013, 07:15:12 pm »
I have a refinement to tweak number 4. It's absolutely dead simple but I just cannot understand the improvement to SQ it has made here.
This is tweak no 4,
4)   Remove power connections from DVD and Floppy Drives etc
The updates is as follows.
For these unused drives disconnect all SATA cables from the motherboard on each of the drives.
Some folks will already be doing this I guess but I wasn't. I was only removing the power connection to the drive to disable it and leaving the SATA cable of the unused drive connected to the Mobo. BIG mistake !
Usual caveats apply, it may not work on other mother board types / DACs and i am only using one HDD (eg no playback drive), but it's dead easy to try out. I really encourage you to give it a try just in case you get the surprising that this has given here this week  Wink
Post back any findings.
« Reply #51 on: March 01, 2013, 08:22:47 pm »
Those connected SATA cables catching what ?
  innocent
neanea
« Reply #52 on: March 01, 2013, 08:32:52 pm »
  innocent
neanea
Judging by the SQ before the SATAs were unplugged, BBC radio 1 I think  rofl
(Possible noise is the reason that the "caveat" is there, but hope tweak to a tweak  Happy works elsewhere)
« Reply #53 on: March 01, 2013, 08:50:06 pm »
My "all purpose" PC had an Intel ICHR9 controller on an ASUS Maximus Formule motherboard (bought in 2007).
I do have an external drive connected through Esata, that is internally connected to one of the internal 6 sata connections (in fact I have 2 of these connections).
I remember having problems when I was leaving the external drive connected while OFF, as if the controller was always asking "Who is there" and sending a signal to that connection.
Now when I don't use this external drive, I disconnect the Esata cable from its enclosure.
This may not occur on all motherboards, but if you try, like Nick says, you could have a nice surprise Happy
listening
« Reply #54 on: March 01, 2013, 10:49:27 pm »
Surprise, surprise ...
Try to unplug your video plug   Grin
Georg
-> SMSL SU-8 ES9038
-> 2x Neumann KH-120
« Reply #55 on: March 01, 2013, 11:16:07 pm »
Georg
Georg hi,
I had been wondering if a KVM switch might be useful to allow the switched disconnection of the monitor whilst music playing.
Is there much of a difference when you unplug your monitor ?
listening
« Reply #56 on: March 02, 2013, 08:47:57 am »
Hi Nick,
it depends. I'm using a television set as PC monitor and the television is connected to cable television. Sometimes (not too unfrequent) I heard some noise in the highs. So I disconnected the VGA cable at the television set during playing music and these noises were gone. Two months ago I had to rearrange my electronics and it was necessary to disconnect the VGA cable from the PC. There is an additional benefit in terms of "free air". Maybe because there is an broadcast antenna not too far away from my home ...
Georg
-> SMSL SU-8 ES9038
« Reply #57 on: March 03, 2013, 02:52:43 pm »
Very nice find Nick. I unplugged three SATA cables from the MB and had a really nice bump in SQ. Though subtle, the sound became cleaner and more focused. Will be an inconvenience when I want to rip music but it's definitely worth the bit of trouble.
« Reply #58 on: March 03, 2013, 03:21:35 pm »
May I suggest the eventuality of getting an external USB CD-DVD player ? It could overcome the disconnect/reconnect problem Happy
« Reply #59 on: March 03, 2013, 04:30:33 pm »
Thanks Allen. I am a little hesitant to go that route cause my best sounding rips have been with my current set up. I guess we need a new topic on best external rippers.
