July 01, 2025, 05:01:55 am *
Pages: 1 [2] 3  All
Author Topic: 0.9z-7-3 Sample Rate not set  (Read 32439 times)
« Reply #15 on: September 14, 2012, 02:58:08 pm »
H Peter,
The sampling rate in the phasure control panel is 352800 KHz (at computer start) & continues to be the same after clicking play in XXHE.
« Reply #16 on: September 15, 2012, 04:10:12 pm »
This problem started with 0.9z-7-3 but now if I use 7-2 it gives the same message.
« Reply #17 on: September 15, 2012, 06:00:55 pm »
Arvind,
It looks to be dependend on timing issues; Today I (hopefully) solved something similar I could copy for "Format Change". This not yet, because I can't mimic it ...
Thanks for letting me know,
« Reply #18 on: September 16, 2012, 10:38:44 am »
Arvind,
What if you uninstall the Phasue NOS driver and reinstall it ?
I have the hunch something is not right in there since I myself am unable to mimic the behaviour. Also, while I thought it was a timing issue, I just saw that there's an attempt lasting 1.5 seconds in there already which really should be enough.
« Reply #19 on: September 16, 2012, 11:18:31 am »
Uninstalled the NOS 1 driver & reinstalled it but I still get the msg "Failed to set sample rate".
« Reply #20 on: September 16, 2012, 12:06:38 pm »
Ok, thanks.
Any other strangenesses maybe you encounter lately ? Maybe especially regarding the NOS1 ?
Did you change anything regarding the OS ? (just asking, because I actually see no relation there)
And what about setting the SFS to eg. 60 ... does that help for this maybe ?
Sorry for your troubles; I just don't get it ...
(but see your remark "it now happens to 0.9z-7-2 just the same")
« Reply #21 on: September 16, 2012, 12:39:32 pm »
It seems that the root cause of both the problems were due to "Start Playback during Conversion" being activated (i guess accidentely/unknowingly). Now having deactivated it everything is solved. Sorry for the trouble.
Gerard maybe you need to look at this too. Hope this solution works for you too.
« Reply #22 on: September 16, 2012, 01:01:25 pm »
Aha !
So maybe *I* look into that, right ?
Glad it is solved Arvind !
PS: But I still wonder whether this low SFS is related ...
« Reply #23 on: September 24, 2012, 02:20:06 pm »
Peter here is one i have. I see now it is a hdcd.
« Reply #24 on: September 24, 2012, 03:41:08 pm »
Gerard, totally OffTopic ...
You can't persist in saying that you don't use the scaling of the OS ... (that is for this other topic, but here is the proof of it).
« Reply #25 on: September 24, 2012, 04:13:37 pm »
 wacko
Did i say that??? Sorry for now i do not know what you mean.
« Reply #26 on: September 24, 2012, 04:23:01 pm »
 OffTopic
If you mean about that blue button.
This is what i have. When i change it to 100% that blue button is not there either.
« Reply #27 on: September 24, 2012, 04:43:11 pm »
Gerard,
(this belongs in that other topic now; do you know which one it is ?)
So what ? does this justify that you tell me that you "for sure" this setting is at 100% ? I don't get it ...
Of course it is. See below. But it is not (in either setting) just after Rescaling - as more is not right - right after that (this is in the Release Notes).
No matter what, I don't see the point in telling things differently from how they are; or do you think that will help you ?
no
« Reply #28 on: September 24, 2012, 04:53:00 pm »
Gerard,
no
I am really sorry i do not understand one word you are saying.
Let it be for now.
Sorry unhappy
« Reply #29 on: September 24, 2012, 05:45:30 pm »
Well, the important part is :
You set your OS scaling to 125% which is not compatible with XXHighEnd's scaling. This is why you have the anomalies (like that vertical bar right trhough everything). This is why I told (in that other topic - where I would like to move these posts to if I knew where to be) that you should set the OS to 100% and XXHighEnd to 125% (1.25) if you want that size. Then all works fine. But additionally, right after using the Scale functionality (or apply a Preset for that matter) the screen is not correct (like the MinOS button lacking). So, quit XX and restart it to get that right again.
Besides, when you use the Scaling of XXHighEnd a bit larger than 100% (1.00) those lacking "numbers" will be there (like in the Preset buttons in the left).
Now, if you can find that other topic for me ...
Pages: 1 [2] 3  All
