July 02, 2025, 02:00:56 am *
Pages: [1] 2 3  All
Author Topic: 0.9z-7-3 Sample Rate not set  (Read 32459 times)
« on: September 13, 2012, 03:15:16 pm »
When I click play I get a message "Sample rate not set". Music plays as usual but I don't know how to get rid of this msg.
« Reply #1 on: September 13, 2012, 03:45:56 pm »
Huh ?
Arvind,
Does this still happen when you kill XXEngine3.exe from memory (click blue led at the right) ?
And otherwise, do you have a screenshot of that message for me ?
« Reply #2 on: September 13, 2012, 06:53:33 pm »
Huh ?
Arvind,
Peter blue led at the right??? Where can i find that?
That message Arvind talks about pups up here also so now and than.
praphan
« Reply #3 on: September 13, 2012, 07:02:59 pm »
Hi Gerard,
Me too. I cannot find the blue led.
Alternatively, please go to the drop down box where you can find and tune Q and Q factor. To the right, there is a box with the word "OFF" inside.  Click that OFF button will kill Engine 3.
I hope I have the right understanding.
Praphan
« Reply #4 on: September 13, 2012, 07:28:11 pm »
See mouse pointer for that blue led ...
« Reply #5 on: September 13, 2012, 07:35:03 pm »
I am really sorry..  unhappy
Where???
« Reply #6 on: September 13, 2012, 09:53:26 pm »
Hi Gerard,
Praphan
Hi Praphan,
Thanx. I know that one.  Happy
But that Blue led  wacko
« Reply #7 on: September 14, 2012, 07:50:07 am »
Where???
Ehm, haha, well, yea ...
Gerard, do you have the scaling in the OS at 100% ?
« Reply #8 on: September 14, 2012, 08:08:05 am »
Ok its like this. When I start the PC, Load playlist & click start I get the msg (attached). If I stop & click play again then the msg does not come back. So it comes at the first play only.
It doesnt matter if engine #3 is killed or running. In both case the msg appears at the first play.
Hope this helps.
« Reply #9 on: September 14, 2012, 08:18:23 am »
Ah. Thank you very much Arvind. That is useful information.
Not that I understand how it happens ...
Btw, this is a typicle NOS1 message. When you think of this in advance at a next reboot, you might first start the Phasure Driver Control Panel and look at the set Sample Rate in there. Maybe it is helpful to me if you tell me what you see. You should see the same I as do here, but still something must be different.
May you encounter that when you first start that Control Panel and now all is okay suddenly, then I also like to know that.
Regards and thanks,
« Reply #10 on: September 14, 2012, 10:05:01 am »
Where???
I have it 100% and i tried 125% also. That are the only settings i can choose.
But both give no blue led no matter what.
« Reply #11 on: September 14, 2012, 10:10:36 am »
Hope this helps.
I see you have it when you start XX.
I have it sometime's in the in the middle of a cd. when a new track starts to play.
« Reply #12 on: September 14, 2012, 12:53:28 pm »
Gerard - Is that with 0.9z-7-3 ?
« Reply #13 on: September 14, 2012, 12:55:43 pm »
Then it must be about the Scaling in XXHighEnd somehow. So, I see you have *that* at 1.00 (or close to that).
I guess I must look into that one ...
« Reply #14 on: September 14, 2012, 01:53:06 pm »
mmmmm Almost certain that it does.
Not much playtime at the moment but i will look for you.
Pages: [1] 2 3  All
