July 03, 2025, 07:22:26 am *
Author Topic: CPU Fan  (Read 20202 times)
« on: April 04, 2016, 05:06:38 pm »
Are the CPU fans still needed? I disconnected one a long time ago. Still have one attached.  Happy
« Reply #1 on: April 04, 2016, 06:02:33 pm »
Phew Gerard, good question.
I'd say it is too dangerous to anticipate on the MinOS + BIOS settings. I mean : if it happens at some time that you're in Normal OS for some reason (happens often enough to me) while also the BIOS accidentally resets, then all is at full power already when you're in the BIOS to set things. If *that* situation allows one cpu cooler fan only, then it is ok.
Let's keep in mind : when the PC came about I was only testing for highest speeds and such and was never bothered by the low speeds we use today. So actually I don't know really ...
« Reply #2 on: April 04, 2016, 07:28:36 pm »
If things goes really wrong i can always buy a cheap xx pc   Wink
Thanx  Happy
« Reply #3 on: April 04, 2016, 09:43:56 pm »
Hi Gerard, I have only one fan in the Audio Pc and that´s the one in the CPU. The fan I use is working at 600rpm and is almost totally silent (6db) so if the problem is noise with this fan the problem is solved because it is absolutely inaudible at more than 20cm from the pc, in fact I can´t hear anything even with my ear almost touching the pc case. On the other hand if the problem is the electrical "noise" (interferences) generated by the fan itself, then the problem still exists. I can work in the bios when I need it without any problem.
This is the fan I use: http://noctua.at/en/nf-s12a-uln
Arjan
« Reply #4 on: April 04, 2016, 10:19:16 pm »
I also have only one fan for the cpu. It is powered by a separate lineair psu at 7V. At one time I forgot to power up the lineair psu, so the fan was not running. After about 1/2 hour or less the music started to stutter...... Cpu to hot. I started the fan and temperature went down. Music was fine again. And this is with MinOS. So yes the fan is needed.
Regards, Arjan
March, 2024 (2.11)
« Reply #5 on: April 05, 2016, 11:47:30 am »
Ok thanx  Happy Will leave it in  Wink
« Reply #6 on: April 05, 2016, 11:59:56 am »
For Juan and others because it could be hard to understand :
What "we" use is the Noctua LH-L12 which as two fans.
So the talk is about "hey we shut off one of the fans already - can the other maybe shut off too ?"
Btw, which of the two did you guys cut off ? The bottom or the top one ? (my guts say the bottom one)
« Reply #7 on: April 05, 2016, 01:09:36 pm »
What "we" use is the Noctua LH-12L which as two fans.
Peter, that's right for the ones that are using the NH-L12 or have your Audio Pc. In my case I only use one fan, the NF Audio S12A ULN, because my PC is not a HTPC and use a heatsink larger than that used in the NH-L12. Thus the NF S12A at 600rpm is sufficient but could not be so in other cases where a cooler with less cooling capacity is used. I searched for the quieter fan possible to maintain an adequate temperature and in the bios I can see that after a couple of hours the temperature does not exceed 42°C, so that will be even lower in Minimize mode.
In conclusion, the CPU fan is necessary. I'm not sure if I understood well if Peter turns the fan Off in Minimize and On when in the bios. Personally I have it always On because the noise is imperceptible and also I can´t lower the CPU frequency as much as Peter.
« Reply #8 on: April 05, 2016, 01:27:36 pm »
Hi Juan,
The CPU fanS run always in my situation. But they are completely inaudible, so it is not about the acoustical noise anyway. The discussion will thus be about the elecrical noise, or actually : power draw. I forgot, but I recall that an average (running) 12V fan consumes 5W.
« Reply #9 on: April 05, 2016, 01:58:10 pm »
Hi Juan,
The NF-S12A ULN (the fan I use) Max. input power is 0,72W http://noctua.at/en/nf-s12a-uln/specification
In your NH L12 is 0,6/0,96 W http://noctua.at/en/nh-l12/specification
So not a big problem in either case, if I´m correct.
« Reply #10 on: April 05, 2016, 03:11:48 pm »
I am not aware of any problem anyway !
If you mean that the consumption is so low that it is not a problem anyway ... correct. But it still is so that everything matters (SQ wise).
« Reply #11 on: April 05, 2016, 03:20:43 pm »
I agree with you Peter but it seems that there´s nothing we can do about it due that we have to use the cpu fan anyway.
« Reply #12 on: April 05, 2016, 04:22:43 pm »
I removed the upper one for a long time without problems. Happy
« Reply #13 on: April 05, 2016, 04:45:01 pm »
Isn't it possible to power the fan(s) voltage controller with an external source ? A linear power supply or a switching power supply ?
« Reply #14 on: April 05, 2016, 04:52:39 pm »
Hi Alain, the fan I use can be powered by the PSU as it comes with an adapter so I imagine that it could also be powered by an external power supply.
Regards
Juan  Happy
